need help with head unit
i finally gottime to do this and then i end up stuck, im swapping my head unit and i got the femal plug that i wired to the head unit as the instructions say and now when i plug it into my car it gets no power at all i dont kno what wrong, i check every fuse and every wire and nothing seems wrong, i need info on this quick
ok checked the fuse, it was blown, i replaced it and tried aagain and didnt work and i checked the fuse and its blown again im pretty sure everything is wired together i match everything how it should except the orange illumination wires i dont kno where they go? should they be connected to the red power wires or what?
If you're using a wiring harness adapter, just match color to color. The orange and red wires do NOT go together... Or, you can do what I do and pull the illumination wire out of the harness adapter and cap the one coming from the deck...
Also, if your radio fuse is blowing when you put it in, you have a short to ground on the constant power wire. Check your wiring...
Trey Boston
Audio / Security / Video
Mar 27, 2019 10:38 AM
4doorRS5spd
Sep 6, 2002 08:29 PM
94
