need help with head unit
Old Jan 29, 2006 | 08:46 AM
AllMtorEg's Avatar
Default need help with head unit
i finally gottime to do this and then i end up stuck, im swapping my head unit and i got the femal plug that i wired to the head unit as the instructions say and now when i plug it into my car it gets no power at all i dont kno what wrong, i check every fuse and every wire and nothing seems wrong, i need info on this quick
Old Jan 29, 2006 | 09:15 AM
B18C_EJ8's Avatar
Did you check radio backup fuse under the hood?
Old Jan 29, 2006 | 10:21 AM
AllMtorEg's Avatar
Default Re: (B18C_EJ8)
where is it under the hood
Old Jan 29, 2006 | 10:35 AM
fcm's Avatar
fcm
Old Fart
Default Re: (SilverBulletEK)
In the under hood fuse box, behind the batt.. probably a 7.5A fuse.
What is the make and model of HU you are installing?
What year is your car? 94
Old Jan 29, 2006 | 11:27 AM
AllMtorEg's Avatar
Default Re: (fcm)
i have the pioneer DEhP3600
going in a 99 EK
Old Jan 29, 2006 | 11:41 AM
AllMtorEg's Avatar
Default Re: need help with head unit (SilverBulletEK)
ok checked the fuse, it was blown, i replaced it and tried aagain and didnt work and i checked the fuse and its blown again im pretty sure everything is wired together i match everything how it should except the orange illumination wires i dont kno where they go? should they be connected to the red power wires or what?
Old Jan 29, 2006 | 12:09 PM
AllMtorEg's Avatar
bump need info now, where to connect orange illumination wires
Old Jan 29, 2006 | 12:42 PM
B18C_EJ8's Avatar
If you're using a wiring harness adapter, just match color to color. The orange and red wires do NOT go together... Or, you can do what I do and pull the illumination wire out of the harness adapter and cap the one coming from the deck...
Also, if your radio fuse is blowing when you put it in, you have a short to ground on the constant power wire. Check your wiring...
Old Jan 29, 2006 | 12:47 PM
AllMtorEg's Avatar
there is no orange wire from the deck and theres a black ground wire from the adapter and a black ground wire from the deck i connected
Old Jan 30, 2006 | 04:32 AM
B18C_EJ8's Avatar
Then pull the orange wires from the harness adapter (or cap them if you can't pull them out).
Trey Boston
Audio / Security / Video
Mar 27, 2019 10:38 AM
Mag00n
Apr 7, 2007 07:44 PM
Tealeg88
Dec 17, 2005 11:26 AM
4doorRS5spd
Sep 6, 2002 08:29 PM
4doorRS5spd
Aug 17, 2002 08:31 PM
