CODE 10 after JDM D15B swap
Well I am getting a code 10 which is the IAT. Can someone post of pic of the IAT looks like. I think it is a little round senor with vacumm lines coming and going near cylinder #1. On the USDM intake manifold there was a nipple on the runner for a vacuum source for the IAT. The JDM intake manifold does not have that nipple...can I just -t- another vacuum line? Did a search.
Any help will be appreciated.
If someone would post a pic of the IAT then we would know.
Post up a pic of what you consider to be the IAT. And any solution you might have for my problem.
Purge Hose?? What do I do with the other vacuum line since the JDM intake manifold doesn't have the nipple? The sensor has two vacuum lines coming out of it. One is going to a cannister looking thing on the passenger side wheel well, the other was suppose to go to the nipple on the intake manifold, on the USDM there was a flange on the intake manifold that the sensor attached to and the nipple was right below it. So what do I do?
Thanks for the help...I just switched the plugs on the IAT and the purge, cleared the codes and they have stayed gone. I must have mixed up those plugs while doing the swap...easy problem to have happen considering the plugs for the IVAC, IAT and Purge are all the same shape.
The car is running very well with the purge vacuum line not even hooked up, however I will get a -t- and tap another vacuum line just to be sure.
TURBOED-TEG
Jan 31, 2006 01:36 PM
