HELLLPPPP
Old Jan 28, 2006 | 04:45 PM
scrapinn's Avatar
Default HELLLPPPP
I recently hit a curb and wacked out my whole rear end i have a 1992 accord lx wat do i need to fix it my rear tirez are rubbing and not drive able
Old Jan 28, 2006 | 06:09 PM
BLKFLSH's Avatar
Default Re: HELLLPPPP (scrapinn)
Damb, that must have been one hell of a wack. Jack up the car, USE JACKSTANDS, and look to see what is damaged. It shouldn't be too hard to tell what is bent or broken.
Old Jan 28, 2006 | 06:26 PM
scrapinn's Avatar
Jus the bac wheel on the left side is bent in
Old Jan 28, 2006 | 06:31 PM
BLKFLSH's Avatar
Default Re: (scrapinn)
Good. Then you have a "good side" to compare it to. Probably quite a few suspension parts are screwed up. Hopefully, the suspension still has good mounting points.
Old Jan 28, 2006 | 06:34 PM
scrapinn's Avatar
I mean the car moves and runs it jus rubbs on the drivers side so it cant b two bad rite?
Old Jan 28, 2006 | 06:39 PM
BLKFLSH's Avatar
I sure can't tell from here hahaha. If it's rubbing, it's probably more than just the bent rim.
Old Jan 28, 2006 | 06:41 PM
P_Adams's Avatar
What you need, is the understanding that you've got to get it to a body shop for an estimate. If it requires hiring a flatbed tow, then by all means do it.
You can't expect well intentioned people to start guessing about something they can't inspect.
It could be any of these:
http://www.hondaautomotivepart...R+ARM
20,22,35,30(twisted) and other stuff which I can't think of
Get it looked at
P
Old Jan 28, 2006 | 06:48 PM
scrapinn's Avatar
Theres no body damage too it
Old Jan 28, 2006 | 06:54 PM
Honda-Master's Avatar
when you hit low like you did,, you won't have any body damage but could have a **** load of suspension damage... you need to take car to a shop and have it checked out ,,most of the time on those hits you bent ,(,control arms )..at times you cannot see the damage with the naked eye , need to have car in the alignment rack and compare the results to the specs .to determine what needs replacing
Old Jan 28, 2006 | 06:55 PM
scrapinn's Avatar
so ta sum dis up watz the range price im lookin at or should i junk tha whole thing
Marcel_14Sport
Suspension & Brakes
Jan 5, 2018 09:57 AM
LaFlamaBlanca
Suspension & Brakes
18
Jan 27, 2013 05:35 PM
alfaaay
Suspension & Brakes
Oct 10, 2006 04:59 PM
pjr710
10
May 9, 2006 08:59 PM
BD7581
Sep 4, 2002 06:32 PM
