new clutch install problems... need specs
Old Jan 28, 2006 | 11:55 AM
93_EH2's Avatar
Default new clutch install problems... need specs
i have a 1993 civic cx hatch with d15b engine and i just bought a new exedy oem replacement clutch and a 96 ex tranny and a new axel... swaped it all in today and started up just fine... when you release the clutch it make a weird loud grinding noise in neutral (maybe other gears too but didn't try)
my friend that was putting it in thinks that he might have over-tightened the clutch bolts... or didn't get them tight enough... what one is it?
i also need the torque specs for the clutch bolts
and if someone could show me a pic of a new flywheel and a pic of a worn-beyond-repair flywheel that would be great
Old Jan 28, 2006 | 11:57 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: new clutch install problems... need specs (x_blindsk8er_x)
if i remember, the flywheel to engine bolts are 70 ft/lbs, and the clutch cover bolts are 19 ft/lbs
Old Jan 28, 2006 | 11:58 AM
veggiemaster's Avatar
i know pressure plate bolts are around 18-20 ft. lbs. while flywheel are around 90 ft. lbs. the torque specs are pretty universal to hondas.
Old Jan 28, 2006 | 02:11 PM
1AB_DOHC's Avatar
noise may be throw out ? dont no
Old Jan 29, 2006 | 09:10 AM
93_EH2's Avatar
Default Re: new clutch install problems... need specs (1AB_DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1AB_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">noise may be throw out ? dont no</TD></TR></TABLE>
its not the throw-out... the clutch came with a new one
but if the flywheel is too worn down will it cause it to make noise when you let off the clutch?
Old Jan 29, 2006 | 12:27 PM
93_EH2's Avatar
actually went back and started it again and i guess it wont go into gear either... like the clutch is engaged... but when i turn it off it goes right into gear, it still makes the loud sound
so i'm guessing that i tightened the pressure plate too tight... does this sound correct?
Old Jan 29, 2006 | 12:30 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
if u are having a problem why not just take it back apart before u make it worse
Old Jan 29, 2006 | 12:44 PM
93_EH2's Avatar
Default Re: new clutch install problems... need specs (street dreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams &raquo;</TD></TR><TR><TD CLASS="quote">if u are having a problem why not just take it back apart before u make it worse</TD></TR></TABLE>
i haven't been driving it... i just started it for 10 seconds max to see if it would go into gear or not
Anyone have an answer??
btw: i do plan on taking it apart this weekend but i kinda want to know if i need to buy anything else or not
Old Jan 29, 2006 | 04:17 PM
93_EH2's Avatar
bump for answers
can someone post up a pic of a new d-series flywheel
it will help a lot
Old Jan 29, 2006 | 04:20 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
if it didn't go in gear, maybe you didn't fully bleed the system. cuz i had that problem and it fixed it, as for the rattling, iono, loose bolts??
Old Jan 29, 2006 | 04:30 PM
tpr's Avatar
tpr
When you installed the clutch did you pay attention to the drirection of the disc? If it goes in backwards, which it can, then the pressure plate cannot release the disc. It is usually marked which side of the disc goes toward the flywheel.
If that is right then I would suspect the pressure plate was not evenly torqued. Torquing the pressure plate evenly is of paramount importance.
Start by hand tightening the 6 bolts (3 at a time) in two triangle patterns. Put the 10 mm 12 point socket onto a 6 inch extension (no rachet). Use that as a nut driver. When you get all 6 seated by hand then add a rachet to the 6 inch extension and work around the clutch turning each bolt only 1/4 turn each time. This pulls the pressure plate down evenly avoiding warping it. they should tighten up and stop turning at about the same number of turns (+/- 1/2 turn). If you did not evenly torque it it may be damaged and require replacement.
Old Jan 29, 2006 | 07:42 PM
93_EH2's Avatar
Default Re: new clutch install problems... need specs (tpr)
my friend was helping my so idk if he was paying attention or not
but are the torque specs 18ft.lbs for the clutch and what about the flywheel?... i have a torque wrench and i got 2 answers above
Old Jan 29, 2006 | 07:57 PM
ABK's Avatar
ABK
yeah take it apart and take some pictures. If you are saying you heard a grinding noise then you will defently be able to tell what was grinding against what.
Old Feb 2, 2006 | 10:23 PM
j-corleon's Avatar
i had the same problem, it ended up being my driver side axle popped out, it was making a grinding noise in neutral. I dont know if this is your problem but check it out, if it is there will be tranny fluid leaking.
Crab-Cakes
Jan 26, 2008 08:42 AM
310HPS2k
Jul 17, 2007 08:21 AM
jdmCivic925
Mar 13, 2004 07:23 AM
drevinder
Jan 18, 2004 09:09 PM
CivicEx95
Apr 24, 2002 10:50 PM
