EG Cluster Problem
Old Jan 28, 2006 | 10:13 AM
American.Graffiti's Avatar
Default EG Cluster Problem
Sup Folks,
I went and bought myself an EX cluster and I didnt install in until after a long while. When I went to go plug it in everything functions properly with the exception of it lighting up. I examined it closely and found this...
The yellow circle outlines the broken circuit.If anyone has ever had this problem and fixed it let me know how to do the same. Any help would be good help. Anything dumb keep to yourself.
Thanks,
-Jeff.
Old Jan 28, 2006 | 10:28 AM
D21X's Avatar
Default Re: EG Cluster Problem (Falkien)
just add some solder in there, or go to the junkyard and remove a cluster and steal the electrical board.
Old Jan 28, 2006 | 10:31 AM
dem0nk1d's Avatar
Default Re: EG Cluster Problem (D21X)
This is a long shot but this will probably work wonders... Which doesn't involve any heat what so ever. So go to the auto patrs store and pick up a rear window defroster repair kit. most people have used it for over clocking cpu's. for closing jumper connections on cpus... you just brush it on and your set... it looks like nail polish for chicks... give it a try.
Old Jan 28, 2006 | 10:46 AM
Default Re: EG Cluster Problem (dem0nk1d)
Ive never tried my hand @ soldering so that will be my last resort. Im gonna try that defroster trick, I hope it works so I dont wreck my board. Thanks for the help.
Old Jan 28, 2006 | 10:55 AM
GetawayInMoscow's Avatar
By a pen with conductive ink.
http://www.mgchemicals.com/products/8420p.html
Screw those other methods
Old Jan 28, 2006 | 11:02 AM
KingKhong's Avatar
Default Re: EG Cluster Problem (GetawayInMoscow)
solder on that think plastic film? I dont think so, don't solder it whatever you do.
Old Jan 28, 2006 | 01:54 PM
Default Re: EG Cluster Problem (KingKhong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingKhong &raquo;</TD></TR><TR><TD CLASS="quote">solder on that think plastic film? I dont think so, don't solder it whatever you do.</TD></TR></TABLE>
Thanks for lookin out.
Old Jan 28, 2006 | 02:10 PM
TK-4004's Avatar
im an electrical engineer...and we use conductive copper tape to test high frequency amplifier boards. it should work great for this application. you can probably find some of this tape a fry's or some other electronic store.
Old Jan 28, 2006 | 03:43 PM
DohcSide's Avatar
Default Re: EG Cluster Problem (TK-4004)
i have the same problem bump
Old Jan 28, 2006 | 04:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TK-4004 &raquo;</TD></TR><TR><TD CLASS="quote">im an electrical engineer...and we use conductive copper tape to test high frequency amplifier boards. it should work great for this application. you can probably find some of this tape a fry's or some other electronic store.</TD></TR></TABLE>
Im new to my area and I dont believe that there is one in my area. Would I be able to find this @ Radio Shack?
Old Jan 28, 2006 | 09:35 PM
TK-4004's Avatar
actually...you might be able to. check their website or give them a call
Old Jan 28, 2006 | 09:39 PM
Stunna MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">This is a long shot but this will probably work wonders... Which doesn't involve any heat what so ever. So go to the auto patrs store and pick up a rear window defroster repair kit. most people have used it for over clocking cpu's. for closing jumper connections on cpus... you just brush it on and your set... it looks like nail polish for chicks... give it a try.</TD></TR></TABLE>
Damn, I need to get that, for my actual rear window defroster. When I was taking off my tint all the defroster lines **** came off with it. Thanks. Ima have to go an pick some up.
Old Jan 28, 2006 | 09:42 PM
TK-4004's Avatar
here's a link to some copper tape
http://shop4.outpost.com/produ...LT_PG
Old Jan 28, 2006 | 11:26 PM
phresh_5's Avatar
Follow the circuit for that burnt wire to that blob of solder. Just solder a wire to that blob and connect the other side to the wire on your harness, done. You might want to use some male/female connectors in the wire so that it can be removed along with the rest of the harness.
Kowal123vtec
Mar 31, 2019 12:15 AM
boostedNOTHARDLY
15
Jul 27, 2010 06:03 PM
Double_Dk
Jun 10, 2004 05:32 PM
