Do JDM headlights use different bulbs?
I noticed that the JDM headlights don't have the glare shield that the USDM headlights have. Is this going to be a problem?
Also, are the bulbs themselves different? When I order replacements, can I juse use H4's or what? I just connected the stock connector and they're good to go right? I just don't want a headlight fire lol.
Here's pics
JDM unit- with city light on
USDM unit-
JDM unit on
USDM unit on
Beam pattern with JDM drivers side, USDM passengers side.
Beam pattern with JDM on both sides
night shot with flash
Night shot in night shot mode - thats just the corners and city lights.
holy **** my car needs to be PAINTED!!
B
Here's pics
USDM unit-
JDM unit on
USDM unit on
B
JDM Headlights use H4H bulbs. I have H4's on mine but it was a problem putting them on since the metal ring on the H4's is bigger than H4H's. Also for the city lights you use a 168 wedge bulb.
Oh ok. So there is a physical difference in the base of the bulb. Any difference in wattage or output? Also, it seems that the H4H bulb (which I assume is in the JDM unit as it came with it) is a bit longer. Can anyone confirm this?
Thanks again all.
B
Thanks again all.
B
