2 questions on B16A wiring
Old Mar 23, 2002 | 04:42 PM
Eggman's Avatar
Default 2 questions on B16A wiring
1. Does the B16A/PWO/PR3 not have a ELD (Electrical Load Detector)?
2. What happens to the ECT switch (located in the thermostat cover)?
tia,
charles
Old Mar 24, 2002 | 12:11 AM
CRX-RX's Avatar
Default Re: 2 questions on B16A wiring (Eggman)
Yes, in Japan there was no ELD system. As for the ECT switch by the thermostat...?????. The only switch by the thermostat I know of is on second and third gen B16's, in which case, you wouldn't need to use that.
Old Mar 24, 2002 | 07:57 AM
89civic1.8T's Avatar
I did a 94 LS swap into my car and that thermo switch had to be used because there wasn't one on the back of the block. It's really easy to do just use the wires that would go to the one on the back of the block. IT doesn't matter if which way they go on because it's an on/off switch. Just get a plug from a 94+ teg or even a 94 + civic. As for the B16 wiring I just did one yesterday and it works just fine. No need for the ELD unit.
Jknower
Honda Motorcycles
Sep 23, 2017 11:49 AM
justinsouza
Audio / Security / Video
Feb 16, 2007 08:13 AM
BB6-213
Dec 27, 2005 12:47 PM
Forbesy
Jan 15, 2005 12:42 PM
SUMORex
Feb 14, 2002 08:34 PM
