Dual pass intercooler conversion
Old Jan 27, 2006 | 10:24 PM
powerofdreams8's Avatar
Default Dual pass intercooler conversion
I have a 24x8x3.5 spearco with standard IC inlet/outlet configuration. I would like to modify the endtanks so that both inlet and outlet are on the same side. Has anyone ever done something like this? Any advice?
Old Jan 28, 2006 | 03:00 AM
awill4x4's Avatar
Default Re: Dual pass intercooler conversion (powerofdreams8)
Here's some pics of one from ARE (Aluminium Radiators & Engineering) ( http://www.are.com.au ) in Queensland Australia, admittedly it is for a rotary and perhaps the inlet/outlet orientation doesn't suit your application but the general design should remain the same.
Regards Andrew.
Old Jan 28, 2006 | 04:21 PM
Default Re: Dual pass intercooler conversion (awill4x4)
That is basically what i want, but i want to convert my existing spearco core. Has anyone doen this sort of modification?
Old Jan 28, 2006 | 04:40 PM
jon volk's Avatar
Just make endtanks configured like the ones above.
Old Jan 28, 2006 | 07:53 PM
KFMRC's Avatar
That core will not work for a dual pass design. You have a core with only 3.5x8"
area that will be cut in half and will not allow enough flow. To mainatain a flow level equal to your current unit you would need a that is shorter and taller 12" long 16" high x 3.5 thick
cvcrtonv
Welding / Fabrication
Apr 5, 2011 10:13 PM
wade
Sep 8, 2010 10:49 PM
Lucky_Smurf
May 20, 2005 02:23 PM
legendboy
Jul 24, 2003 09:35 AM
