Rusty rotors?
Old Jan 27, 2006 | 06:56 PM
PhatBoy5015's Avatar
Default Rusty rotors?
I just finished my rear disc swap on my 97 HX and the rotors rust pretty bad. I'm not really worried about the rust on the friction area but the part that covers the hub. What is the best way to clean it and keep it from rusting?
Old Jan 27, 2006 | 07:00 PM
pdiggitydogg's Avatar
use them, the rust will be cleaned off
If you dont want the hub of the rotor to rust...ts
Old Jan 27, 2006 | 07:05 PM
sicky's Avatar
grammer nawzi
Default Re: (pdiggitydogg)
Resizing your photos is a good way to remove rust.
Old Jan 27, 2006 | 07:11 PM
SOHC4life 96's Avatar
Default Re: (sicky)
Sand the hubs then paint them with some high temp paint. Did it to my rotors and they haven't rusted (much). There are a couple parts that I missed but for the most part they are rust free.
Old Jan 27, 2006 | 07:18 PM
EG2Driver's Avatar
Default Re: (SOHC4life 96)
yea since they're rear, the high temp paint should work. I dont know about hte fronts tho. Mine were said to be zinc coated, and it seems to be working. I also live in salt capital of Canada. The put salt on the road like its no body's business. My car is rusting from places i thought it couldnt rust from.....whadda biatch
Old Jan 27, 2006 | 08:08 PM
I'll tell you...paint doesnt work
Old Jan 27, 2006 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">I'll tell you...paint doesnt work</TD></TR></TABLE>
It works here in SoCal. I think there's a lot of variables on whether it will work well or not. Like say in a state where they use salt on the roads it probably won't work well.
It's not 100% but it works enough to please me. *shrugs*
Old Jan 27, 2006 | 09:21 PM
nello a.'s Avatar
powder coating. bulletproof
Old Jan 27, 2006 | 09:45 PM
old man neri's Avatar
Default Re: (nello a.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">powder coating. bulletproof</TD></TR></TABLE>
not totally
the real problem is that painting rotors leaves and edge, an edge where the paint stops and the rust starts. The rust works it's way under the paint and eventually lift it off. again environment plays a big role. If you live in MTL like "soch4life 96" or ottawa like me you are pretty much screwed, cali....life is a little easier.
I didin't acutally know you could mask stuff off and powder coat it but apparently you can. "nello a" how did the powder coat work out, was it flakey at the edge where they masked it off?
If I were you I would just live with it or just paint it with "brake paint" and expect to paint it every year or so. Oh and after a while the rust will not be as bright red, it will be darker and less noticible.
Cheers.
Old Jan 28, 2006 | 12:35 AM
Contender25
Guest
Posts: n/a
Default Re: (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">Resizing your photos is a good way to remove rust. </TD></TR></TABLE>Lol really..no offense.
Old Jan 28, 2006 | 12:48 PM
rust is almost non-existant in socal as it is...
Old Jan 28, 2006 | 02:12 PM
Targa250R's Avatar
be professional
Default Re: Rusty rotors? (PhatBoy5015)
They're made of cast iron. They're going to rust.
Old Jan 28, 2006 | 02:37 PM
veggiemaster's Avatar
Default Re: Rusty rotors? (Targa250R)
honestly, dont put a lot of money into it. Rotors are a wear item, you are going to replace them anyway. Temporary fixes are your best way to go, and just keep re-doing it. Either that, or live with it. I live with mine.
Old Jan 28, 2006 | 03:03 PM
igo4bmx's Avatar
ive found that tire shine and wheel cleaners make the rotors rust...
i don't use them and my rotors have barely rusted
Old Jan 28, 2006 | 03:08 PM
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">ive found that tire shine and wheel cleaners make the rotors rust...
i don't use them and my rotors have barely rusted</TD></TR></TABLE>
well ya. First you use all the cleaners that disolve all the oil off the metal, and then you blast it with water. Of couse that will cause more rusting.
Old Jan 28, 2006 | 04:50 PM
EG2Driver's Avatar
Default Re: (old man neri)
i envy anyone who lives anywhere there is no salt. I hate this **** hole.
Old Jan 28, 2006 | 07:31 PM
Sleepy_Red_hatch's Avatar
Default Re: (deadend9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 &raquo;</TD></TR><TR><TD CLASS="quote">i envy anyone who lives anywhere there is no salt. I hate this **** hole.</TD></TR></TABLE>
i feel you bro....my car is white right now, i miss summer when it used to be red
Old Jan 28, 2006 | 10:46 PM
Contender25
Guest
Posts: n/a
It never snows down here, i have maybe seen like 2 inch of snow in my entire life and that was like 10 years ago.
Old Feb 3, 2006 | 05:39 AM
SiCiViC2000's Avatar
Painting that area should work as long as you sand, scrap, and clean the hell out of them before hand. Otherwise the paint won't stick and it will rust all over again
Old Feb 3, 2006 | 06:55 AM
dpkelly's Avatar
Default Re: (SiCiViC2000)
Get them anodized. I had mine anodized and on my car for about 8 months now and no rust. The anodizing gives them a golden look. I used a cheap set of Canadian tire rotors. You'll have to machine them after the anodizing to remove it from the breaking area. Just do some web research on anodizing and find a place that'll do it for you.
Old Feb 3, 2006 | 07:15 AM
Seriously though, why waste money on getting rotors anodized??
They are a wear item... Its cheaper just to replace them than to resurface. Crazy.... I can see trying to paint them if you have the paint sitting around, but I wouldnt even go out and buy paint to do this.
If you want to throw more money away, send it to me instead
Old Feb 3, 2006 | 08:16 AM
dpkelly's Avatar
I can see your point pdiggity but in a salty environment, it's just a pain to have to replace them year after year. It's easier just to prevent the rust and have piece of mind. When the cooling finds don't rust, heat dissipation is easier and they are less likely to warp. Although if he intends on rough usage, brembo would be a better brand with anodization.
Old Feb 3, 2006 | 08:18 AM
I bet theres the same amount of salt here, if not more because the road commission has a deal with the "big" 3
That amount of rust isnt going to destroy rotor hubs in anything less than a decade.
Old Feb 3, 2006 | 08:19 AM
Blazin Si's Avatar
Loved
Community Favorite
Aren't nickle plated rotors suposed to stay rust free? There's something they can plate the rotors with to keep them from rusting.
kornerk12
Jan 18, 2006 05:18 PM
Supraznki
Jul 29, 2005 09:19 PM
GrayT
Sep 15, 2004 11:40 AM
fastcrxsi90
Nov 15, 2002 02:06 PM
Kazmans94cord
Mar 29, 2002 07:09 AM
