Fully Built Turbo'd f23a1 or H Swap
Old Jan 27, 2006 | 04:50 PM
casmello's Avatar
Default Fully Built Turbo'd f23a1 or H Swap
Im very limited money wise and just curious as to what you guys would prefer to do.. I was thinking of just fully building my engine now f23a1 and then turbo it. or what i WANT to do is put the h22 in and maybe a small kit? Which would end up with more power, and which would go for less money? My engine has 88,000 on it now.
*I also recently heard something about you can swap a rsx motor in and itll fit fine? true?
Old Jan 27, 2006 | 08:16 PM
D16Z6racing's Avatar
Default Re: Fully Built Turbo'd f23a1 or H Swap (casmello)
H series IMO.
I'm looking to H23 auto my Accord.
Old Jan 28, 2006 | 06:40 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by casmello &raquo;</TD></TR><TR><TD CLASS="quote">Im very limited money wise </TD></TR></TABLE>
turbo is not for you.
Old Jan 28, 2006 | 07:24 AM
Corruption's Avatar
F23 will yield more horsepower for the same price that you'd spend on the H22, however, the reliability is questionable. It all depends on the condition of your engine, the tune, and the parts you use.
Old Jan 28, 2006 | 07:34 AM
iam7head's Avatar
Default Re: Fully Built Turbo'd f23a1 or H Swap (D16Z6racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing &raquo;</TD></TR><TR><TD CLASS="quote">H series IMO.
I'm looking to H23 auto my Accord.</TD></TR></TABLE>
i would go for f23
1)because everything is so much cheaper for F
2)lower compression
Old Jan 28, 2006 | 09:05 AM
5 Speed AP2's Avatar
Default Re: Fully Built Turbo'd f23a1 or H Swap (iam7head)
You had mentioned money would be limited....so....is this going to be your daily driver?
If so, I'd say steer away from turbo. Take into consideration tuning costs and the regular "my **** ain't running right" scenarios that a daily driver can't afford to have.
Old Jan 28, 2006 | 09:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
i would go for f23
2)lower compression</TD></TR></TABLE>
The F23 option is turbo....turbo is not cheap. H swap is factory and has reliability.
Old Jan 28, 2006 | 01:05 PM
iam7head's Avatar
The F23 option is turbo....turbo is not cheap. H swap is factory and has reliability.</TD></TR></TABLE>
how much a stock h22 makes? 165ish on dyno.
i think you got a point if the someone is looking for a super relaible daily driver, but again how much is the 6th gen weight?
Old Jan 28, 2006 | 07:19 PM
glamXXXrock's Avatar
Honestly, If you're very limited budget wise, Neither is a good Idea until you really can afford to do it.... the H swap would be reliable, but it takes money...
Old Jan 31, 2006 | 07:41 AM
casmello's Avatar
Guess I better start savin haha
Old Jan 31, 2006 | 08:06 AM
LookingForVTEC's Avatar
Don't build the F 23 just do a really nice turbo kit. That would be cheaper than trying to do the swap. If you start having problem with the F23 then build it. Just my two cents
Old Jan 31, 2006 | 09:36 AM
chile's Avatar
Default Re: Fully Built Turbo'd f23a1 or H Swap (5 Speed DC2)
if you're gonna stay low boost (6-7 psi), boost that thing...but you will have to take into consideration, the mileage and condition of the F23...a compression test is a good idea...
Old Jan 31, 2006 | 09:56 AM
ChanManDC5's Avatar
i'm wondering about this issue also too.. just not taking an option for the H swap.
for F23a motors, are FI setups recommended for milages over 88k ( casmello's F23a1) and 100,598 (my F23a4) ??
any inputs well appreciated.
Old Jan 31, 2006 | 10:20 AM
notoriousB's Avatar
Default Re: Fully Built Turbo'd f23a1 or H Swap (ChanManCG3)
mileage doesn't matter. how is the compression on the motor?
boost breaks ****. be ready for more $$ spent than initially thought.
Old Jan 31, 2006 | 10:31 AM
cdsquad.net's Avatar
Default Re: Fully Built Turbo'd f23a1 or H Swap (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">boost breaks ****. be ready for more $$ spent than initially thought.</TD></TR></TABLE>
Know this from personal experience
thebiglou
Apr 7, 2007 02:08 PM
pd0019
Nov 15, 2006 05:26 PM
Turbocivic94
May 15, 2004 10:14 PM
tonesdef
Jul 20, 2003 09:39 PM
nsx29
May 11, 2003 03:14 PM
