Nitrous Im thinking about doing a 50 shot here for the track is nitrous safe for b series motors??
Old Jan 27, 2006 | 02:55 PM
Markb16a's Avatar
Default Nitrous Im thinking about doing a 50 shot here for the track is nitrous safe for b series motors??
Like the topic says I am bout to put on a 50 shot and see whats going to happen but Im not sure yet we have a new 1/4 mile track opening up on the ws of jax in june and I want to be in line for it. So I wanted to spray it a lil. is it safe and what is your set ups and where do you mount your bottles at?
Old Jan 27, 2006 | 03:17 PM
AaronJ's Avatar
Default Re: Nitrous Im thinking about doing a 50 shot here for the track is nitrous safe for b series motors
You will be plenty fine with just a 50 shot setup. Make sure you run a wet kit, and have a good fuel pump (walbro 190lph will do). You can definately spray 75 no problem on a wet kit. You need to get colder spark plugs and gap them closer.
I ran a setup just like this on my b16, with the timing retarded 2 degrees at the dizzy, and it ran great all summer long.
Old Jan 27, 2006 | 04:04 PM
91B16HF's Avatar
How quick was it and which kit did you run?
Old Jan 27, 2006 | 06:37 PM
Rex18c's Avatar
I have a jdm gsr with 55 shot zex dry kit with full msd ignition and fuel upgrade. I could spray all day with no problems at all. I took out my spare tire and mount my bottle there. At the track, I ran low 14's without nitrious and low 13's with nitrious on street tires with 2.2-2.4 60 '.
Old Jan 27, 2006 | 08:30 PM
DocSean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91B16HF &raquo;</TD></TR><TR><TD CLASS="quote">How quick was it and which kit did you run?</TD></TR></TABLE>
He was running the NOS kit, best time of 13.9...albeit bottle pressure was never optimal. Make sure if you do it, get a bottle heater to modulate nitrous pressure and consider running an ignition unit like the MSD that can retard timing upon nitrous activation.
Got Milk
Jan 1, 2005 01:08 PM
TO_SLOWGSR
Feb 19, 2004 04:01 AM
STEV3-O
May 19, 2003 08:12 AM
blacklude
Oct 14, 2002 01:57 PM
anotheraznguy
Feb 23, 2002 10:00 AM
