help Please!
i am looking for some sort of diagram that explains where to connect all the connectors from the inside of the car to the engine its for a 90 crx ... as in for example, the radio. where are they located and what do they look like?
Please any info would help..
T.I.A. (Thanks in Advance)
No offense, but under the dash is pretty obvious. Theres the gauge cluster, then the harness for the key. Then theres the one for the cluster pod, such as the dimmer and hazard. Then there the one for the clock, it has a grommet on it. Then theres the one for the fuse box. Then theres the one for the radio and climate control. I had 100% of my interior out and the wiring was just resting on the floor, I got mad one day and did it all and put my CRX Si dash in. It's seriously some easy to do.
It's pretty self explaining once you start clipping them in. They only go in one spot. I had some clips left over in the cluster cause it was automatic.
Hey its rockys b/f. I need the entire interior harness and engine harness. Problem is im getting fuel and low spark. About to test the compression friend said it had none im testing it in a few.
sohcdestruction
Feb 14, 2008 12:36 PM
racecarpete
Apr 23, 2003 07:00 AM
