retap or heli-coil
Old Jan 27, 2006 | 09:27 AM
gsrious's Avatar
Default retap or heli-coil
help...
https://honda-tech.com/zerothread?id=1507172
Old Jan 27, 2006 | 10:27 AM
Racermech's Avatar
Default Re: retap or heli-coil (gsrious)
That is a hard one, Are the threads just messed up, or are they gone??? If they are gone there is nothing to re-tap. You could run a tap just to try and clean up the other threads. and hope for the best.
If the threads are gone, and the other threads do not look so good I would say do the heli-coil. If a coil is done right they can be very strong, I jsut would recemend being very carfull when replcing plugs and how tight you put the, and on the coil make sure to use anti-sieze just incase something does happen, that way you dont pull the coil out and totally screw yourself.
Old Jan 27, 2006 | 11:09 AM
TRE_'s Avatar
Default Re: retap or heli-coil (Racermech)
I would try to get something like this re-tapped. Heli-coils work good, but for a spark plug hole I would want more of a "real" fix.
EcityEP3
Jul 21, 2010 02:28 PM
EGLUVN
May 17, 2007 12:53 PM
hatchblack
Honda S2000
Oct 18, 2006 10:22 PM
gottagofaster
Oct 22, 2005 04:50 PM
gottagofaster
Oct 21, 2005 11:58 PM
