allignment help
Old Jan 27, 2006 | 09:23 AM
imskatencrzy's Avatar
Default allignment help
my eg is pulling to the right. its not really sharp but its aggravating and i dont want to ever take my **** to a shop. does anyone know how to adjust that with out an allignment rack? thanks
Old Jan 27, 2006 | 09:25 AM
hott95ej2's Avatar
Default Re: allignment help (imskatencrzy)
are you serious? get and alignment ! also shake it down, check all balljoints, tie rod ends etc. and is your suspension cheaply modified?
Old Jan 27, 2006 | 09:35 AM
Default Re: allignment help (hott95ej2)
nah its dropped 2 in on tein sport springs, and thats it.
Old Jan 27, 2006 | 11:23 AM
eastbay925's Avatar
cross the front tires and see what happens, if it pulls the other way its you tires
Old Jan 27, 2006 | 11:37 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imskatencrzy &raquo;</TD></TR><TR><TD CLASS="quote"> does anyone know how to adjust that with out an allignment rack? thanks</TD></TR></TABLE>
Yup. You'll need toe plates: http://www.longacreracing.com/...tid=5.
Since you're pulling, you'll need to do a 4 wheel alignment, wich will require 'stringing' the car to make sure both axles are pointed straight:
https://honda-tech.com/zerothread?id=597192
With the toe plates, you'll only need to string one side, instead of boxing it, which I find much easier. I change my alignment all the time between track and daily driving. Read all those links many, many times to figure it out.
sony224422
Aug 28, 2007 07:40 PM
chadalac1712
Dec 22, 2006 09:45 AM
fhtfhatchy
45
Oct 26, 2006 05:59 AM
RCautoworks
May 16, 2005 02:29 PM
slammed00si
Mar 20, 2004 11:09 PM
