JDM HEADLIGHT QUESTION????
soo i finally got the H4H headlight wiring harnesses off of passwordjdm.com, and i was wondering does anybody know what color wires you connect to what.....the harness has a red, white, and yellow wires, any help on which color wire i connect to which wire on the harness would be greatly appreciated
well that was a lot of helpful responses...
i can't remember the colors, but the reason is because it was so easy. take the plugs to the jdm headlights and compare them with the wires for your existing headlights. i cut and spliced them in. the jdm's have 2 power and 1 ground per plug. yours have a power and ground for each bulb(4 plugs total). hook up the corresponding power wires and one of the grounds. tape off the extra ground pn each side. plug in the bulbs and you are good to go.
Jdmsolutions
Dec 28, 2012 08:01 AM
Mixmasta
Jan 27, 2009 05:32 PM
vtec_head
11
May 12, 2006 05:51 PM
