ignition problems check all...
ok got a new distributor checked all fuses replaced the pg e/m fuse tryed starting no spark.... checked all others fuses also i really need help guys.
check to make sure the distributor isn't clocked 180 degrees the wrong direction. also check the plug for the distributor make sure everything lines up.
when we took the old distributor off we made shure the new one was in the exact same position as the old one... this is just pissin me off and i wish i could get this fixed soon
checked coil reads .6 so coil is good. imma change the wires and plugs in about 20min then we will know if i have spark
wood 1
12
Sep 24, 2006 01:37 PM
