Vibration when braking?
Old Jan 26, 2006 | 08:43 AM
smetzger's Avatar
Default Vibration when braking?
1992 Accord.
When braking firm but not slamming on the brakes and going between 30-40mph I can feel vibration in the steering wheel.
What is the probable cause for this?
I suspect brakes but wanted to see what others say.
Thanks,
Scott
Old Jan 26, 2006 | 09:04 AM
snowshooz's Avatar
Default Re: Vibration when braking? (smetzger)
When was the last time you serviced the brakes? It could be your rotors/drums etc. or since you say it only happens at 30-40 mph it could be an out of balance tire/wheel compounded by a worn shock or strut.
Can you tell if the vibration is coming from a specific side fron or back?
Old Jan 26, 2006 | 09:20 AM
P_Adams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smetzger &raquo;</TD></TR><TR><TD CLASS="quote">1992 Accord.
Thanks,
Scott</TD></TR></TABLE>
Generally speaking:
Vibration felt in steering wheel: Front Suspension items (issues)
Vibration felt in seat: Rear suspension issues.
For Example: Front
Applying brakes: Brake Rotors out-of-parallel (Warped) One -or- both
W/Out Applying brakes: Broken Tire Belt (causes a side/side weeble), Out of Balance Tire (s). Bent Rim.
For Example: Rear
Applying brakes: Brake Rotor/Drum out-of-round (causes a surging effect as the brake momentarily grabs, then releases)
P
Old Jan 26, 2006 | 09:31 AM
YeuEmMaiMai's Avatar
rotors are the first thing I would look at. Those things are a PITA since they are pressed on...........
Old Jan 26, 2006 | 09:35 AM
P_Adams's Avatar
Default Re: (YeuEmMaiMai)
What? An Animal rights group "PITA" is involved with Honda Brake Rotors?
That explains why it's such a "Pain in the Drain", and it's often advised you don't wear furs when performing brake jobs. It's all become very clear....
P
Old Jan 26, 2006 | 09:37 AM
Default Re: (P_Adams)
I thing you are referring to PETA
PETA = people eating terrified animals
PITA = pain in the ****
Old Jan 26, 2006 | 09:52 AM
P_Adams's Avatar
Literary License (I guess)
But really, they <U>are</U> really one in the same
Careful, they may show up protesting you're humerous (but Politically Incorrect) comment
"People for the Ethical Treatment of Animals"? Yeh, Right!
P
Old Jan 26, 2006 | 11:51 AM
Brandon's Avatar
Life is Suffering
I would also check the front suspension and tie rods for play, my 5g has some bad bushings on the LCA and the same thing happens to me.
Old Jan 26, 2006 | 12:20 PM
damnhao's Avatar
i have a similar problem: braking from 130-80mph np problem; braking from 80-60mph, wheel shakes a lot; from 60-0mph, no problems. i have a 91 accord, and yes it still can hit 130 no problems
Old Jan 26, 2006 | 12:21 PM
Default Re: (damnhao)
check your wheel balance and them your ball joints.
Old Jan 26, 2006 | 05:30 PM
smetzger's Avatar
Default Re: Vibration when braking? (snowshooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowshooz &raquo;</TD></TR><TR><TD CLASS="quote">When was the last time you serviced the brakes?</TD></TR></TABLE>
brakes have 53 kmiles.
shocks have 253 kmiles.
I'm guessing its brakes, + possible shocks + possible warped rotors
I'll post results after I look at it
Thanks for the help.
Scott
Old Jan 26, 2006 | 05:35 PM
amckee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">PETA = people eating terrified animals
</TD></TR></TABLE> I always heard PETA = People Eating Tasty Animals
Old Jan 27, 2006 | 01:00 AM
Fook_me_honda's Avatar
Default Re: (amckee)
My does the same thing, except its my cv joints that have gone out, when it was real bad it would just shake like crazy...
Old Jan 27, 2006 | 05:42 AM
noobie's Avatar
do not waste your time with anything else,, machine the frt rotors if thick enough, replace them if too thin
Old Jan 27, 2006 | 05:27 PM
importfanatic17's Avatar
Default Re: (noobie)
I had the same problem (kinda). Mine would shake a little bit when I braked from like 30 mph. I figured it was from the accident that I got into (tried to take a 90 degree turn at 80+ mph), it wasn't. All I did was get my tires balanced and then it was all good...try it!
Old Jan 30, 2006 | 08:14 AM
smetzger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">rotors are the first thing I would look at. Those things are a PITA since they are pressed on...........</TD></TR></TABLE>
Shop says its brakes + rotars.
They are charging me extra because they are a PITA
Old Jan 30, 2006 | 03:06 PM
P_Adams's Avatar
Default Re: (smetzger)
Actually, If it were my shop, I would have told you it's Rotors and Brake Pads.
The Rotors because they are the source of the vibration, the pads because they've either gouged the rotors, or they've worn to the point of needing replacing.
It was what I expected.
P
anlee
Apr 26, 2012 12:14 AM
TOO MUCH TORQUE
Aug 15, 2010 06:53 PM
JDM_rolex
18
Oct 7, 2007 08:30 AM
redteg1
Apr 1, 2004 11:24 PM
Evoluti0n
Mar 3, 2004 02:44 PM
