GM 3bar VS. AEM 5bar
Old Jan 25, 2006 | 10:23 PM
dunkd's Avatar
Default GM 3bar VS. AEM 5bar
obviously the aem can read a higher range but are there any other benefits to running the aem?
just trying to figure out if the extra $90 is worth it.
Old Jan 25, 2006 | 10:52 PM
Mase's Avatar
Default Re: GM 3bar VS. AEM 5bar (dunkd)
if there is any chance of you going higher than 28 psi, dont get the gm 3 bar.
im not a big electronics nerd, but apparently the gm 3bar doesnt read vac as good. i havent really noticed a difference tuning however.
the aem 3.5 bar is a good median as well...
Old Jan 26, 2006 | 03:29 AM
Turbocivic94's Avatar
I use to run 3 bar map before and now I run 5 bar map. Only reason I switched cause I wanted to boost over 28 psi. I think gm 3 bar is more reliable than aem 5 bar. I had one go bad on me already.
Old Jan 26, 2006 | 04:42 AM
Dragline's Avatar
Default Re: GM 3bar VS. AEM 5bar (Turbocivic94)
The obvious and you can eliminate a vac. line and can just screw the 5bar into you vac. block or intake manifold..
Old Jan 26, 2006 | 05:04 AM
SpeedDreamz.com's Avatar
Default Re: GM 3bar VS. AEM 5bar (Dragline)
The aem looks prettier and shiny.
Old Jan 26, 2006 | 05:21 AM
Enzo-Racing's Avatar
Default Re: GM 3bar VS. AEM 5bar (SpeedDreamz.com)
You always want to use a map sensor as close as possible to the amount of boost your going to run. If your going to run under 30psi there is no need to even consider the 5bar.
Old Jan 26, 2006 | 05:54 AM
cuin9sec
Guest
Posts: n/a
im selling my gm 3 bar if you need one. im upgrading to 5 bar soon. pm me if you want it.
Old Jan 26, 2006 | 12:53 PM
JDogg's Avatar
Default Re: (gt42r_civic)
the gm sensor is not as linear as the aem sensors. the higher the boost goes the farther from "real" it gets. they werent really designed to opperate at higher boost levels.
Old Jan 26, 2006 | 01:17 PM
Default Re: (JDogg)
I had mine threaded in the factory map sensor place. I just tapped the whole bigger.
Old Jan 26, 2006 | 05:43 PM
AR Fab's Avatar
Default Re: (Turbocivic94)
How did the AEM sensor break?
did it fail electronically or did it literally break?
Howard
Old Jan 26, 2006 | 06:45 PM
dunkd's Avatar
Default Re: (AR Fab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AR Fab &raquo;</TD></TR><TR><TD CLASS="quote">How did the AEM sensor break?
Howard</TD></TR></TABLE>
yah 140$ isnt exactly cheap to replace
Old Jan 27, 2006 | 04:47 AM
It internally failed and AEM replaced it
Old Jan 27, 2006 | 04:51 AM
Turbo-charged's Avatar
i had a customer bring me an AEM box that he bought online...and (go figure) it had been messed with and wouldnt work...it looked like somebody tried to solder the inside of it with cheezeburgers, poptarts, and mig welds........ sent it to aem to see what would need to happen in order for it to be fixed.......they over night shipped it to me ($60) the very next day with the whole insides replaced free of charge. i couldnt beleive it.
i have an AEM wideband here that gernaded itsself internally...i wonder if they will fix that too. i hear of a lot of failures with their stuff, but i was amazed with the customer service.
this has nothing to do with map sensors, god im awesome lately. im like that random guy who posts crap...and you read it ..and then your like "why the hell did i just read that"
Old Jan 27, 2006 | 07:34 AM
JDogg's Avatar
Default Re: (Turbo-charged)
the only time i have seen an aem map sensor fail is when it was wired wrong... i have installed hundreds of those things.
Old Jan 27, 2006 | 05:49 PM
1FSTHATCH's Avatar
Default Re: (dunkd)
Had the AEM 5 bar map for 2 years, still not one problem..
I would go with AEM
Old Jan 27, 2006 | 06:48 PM
WillieWillieFast's Avatar
I have the AEM 5 bar. No problems
Old Jan 27, 2006 | 07:12 PM
tony1's Avatar
Default Re: (WillieWillieFast)
Not sure who makes the new aem sensors, but alot of you probably have the older one made by Kavlico. It's a very good sensor, same sensors motec uses/sells.
Old Jan 27, 2006 | 07:24 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (tony1)
why do you always have to bring up motec in every post!!
Old Jan 27, 2006 | 11:18 PM
Default Re: (tony1)
Tony i believe it's SSI
Btw: those stating awesome reliablility let's remember that AEM doesn't make the map sensor....
Old Jan 28, 2006 | 12:52 AM
Adi Radoncic's Avatar
On Fire!
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">why do you always have to bring up motec in every post!!</TD></TR></TABLE>
Tony Motec Palo
lol
Old Jan 28, 2006 | 05:44 PM
NLR's Avatar
NLR
ssi sensors are exceptionally good...use them for all our controls and with the motecs we set up. We stock the 75 psi absolute .
Old Jan 28, 2006 | 06:12 PM
SkRiBLaH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i had a customer bring me an AEM box that he bought online...and (go figure) it had been messed with and wouldnt work...it looked like somebody tried to solder the inside of it with cheezeburgers, poptarts, and mig welds........ sent it to aem to see what would need to happen in order for it to be fixed.......they over night shipped it to me ($60) the very next day with the whole insides replaced free of charge. i couldnt beleive it.
this has nothing to do with map sensors, god im awesome lately. im like that random guy who posts crap...and you read it ..and then your like "why the hell did i just read that" </TD></TR></TABLE>
why the hell did i just read that?
mycarslow
Engine Management and Tuning
Nov 28, 2015 08:53 AM
SwappedTURBOegg
Jul 26, 2009 10:03 PM
Boosteddb8
Jun 12, 2007 03:24 PM
BB6-213
Apr 27, 2007 03:54 AM
Turbocivic94
Feb 27, 2006 09:11 AM
