Do any preludes in USDM have heated side mirrors?
Old Jan 25, 2006 | 03:46 PM
99CivicSiBrian's Avatar
B A N N E D
Default Do any preludes in USDM have heated side mirrors?
Just as the topic states.
I'm trying to hook up the ones I got on my JDM mirrors on my civic but haven't had any luck with the defroster part of the wiring. Any ideas?
I'll be asking in other forums as well.
B
Old Jan 25, 2006 | 03:53 PM
hu's Avatar
hu
The heated side mirrors were available in Canada and Europe.
Old Jan 25, 2006 | 04:35 PM
B A N N E D
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">The heated side mirrors were available in Canada and Europe.</TD></TR></TABLE>
Yes same thing with the civic, but I can't get ahold of any Canadians or Europeans who can help with the wiring.
B
Old Jan 25, 2006 | 04:55 PM
redtop22's Avatar
heated mirrors are sweet, i love 'em
what do you need in terms of wiring ?
Old Jan 25, 2006 | 05:58 PM
Shaggy's Avatar
Default Re: (redtop22)
What are the benefits of heated mirrors?
Old Jan 25, 2006 | 06:03 PM
hu's Avatar
hu
^ Keep snow & ice off.
Old Jan 25, 2006 | 06:49 PM
redtop22's Avatar
^ definetly makes it easier to take off ice build up and helps alot when they fog up in the mornings.
Old Jan 25, 2006 | 07:11 PM
M@'s Avatar
M@
There are several Peeps here including me that have the Canadian prelude.
Whats your question maybe I can help?
Old Jan 25, 2006 | 08:48 PM
B A N N E D
Default Re: (M@)
Well, my questions are numerous. I assume the tech would be the same from Civic to Prelude of course.
Are they hooked up to a relay?
Are they activated by the rear-defroster button, or another button?
Why would there be 2 wires for the defroster? Seems like a signal is all that would be necessary as there's already power and ground in the door. Since there are 2 wires, what do they do and how would they hook up?
It's tough to just 'trial and error' hook this up because you can't really 'see' the defroster work otherwise I guess I could figure the mirror end out.
Old Jan 25, 2006 | 10:42 PM
The Phil's Avatar
Default Re: (99CivicSiBrian)
The two wires are probably power and ground. That way, since heated mirrors were an option (i believe), they could use the same harnesses for everything else and just have a separate harness for heated mirrors. Otherwise, they'd have to have a tap of some sort run off the power wire in the door, or some sort of connector that was different between different models, which would be more expensive. It'd just be cheaper to have a separate harness like that.
Old Jan 26, 2006 | 05:10 AM
Sephro's Avatar
Default Re: (The Phil)
They sell kits you can put them in your stock wing mirrors.
However I have no idea how well they work..
Old Jan 26, 2006 | 06:40 AM
92LudeSR's Avatar
Default Re: Do any preludes in USDM have heated side mirrors? (99CivicSiBrian)
I don't have any info on the wiring portion but they are turned on via a switch located where the power window controls are, at least on a 92 anyway. They are completely independant of the rear defrost.
Old Jan 26, 2006 | 06:19 PM
redtop22's Avatar
Default Re: Do any preludes in USDM have heated side mirrors? (92LudeSR)
on a 5th gen the push button switch is located to the left of the power mirror controls.
and the phil is correct. there are two wires. one for power (orange/white wire), and the second that is a ground (black).
Modified by redtop22 at 9:03 PM 1/26/2006
Old Jan 26, 2006 | 09:52 PM
B A N N E D
Default Re: Do any preludes in USDM have heated side mirrors? (redtop22)
hmmm. . . so the way the defrosters work, does it matter which way these wires are hooked up? Sounds like a dumb question, but if there's nothing on the circuit but a 'resistor' which creates heat, it shouldn't matter which way it's connected.
Ok, so I guess I need to find out how the Civic is setup, because I don't remember ever seeing any anywhere with a button on the mirror switch for the defroster. I'll ask in EG forum again.
In the meantime, let me know if there is indeed a relay for timing, or if it is just an on/off switch.
B
bakomack
14
Jul 31, 2009 05:04 PM
jcsurfer8386EF
16
Jan 12, 2009 04:13 PM
MistaH eK
Jun 14, 2007 04:54 AM
