LS FPR
You need some sort of guage, so you can see how much pressure the fuel system is pushing. A stock LS should run somewhere from 36-42 psi. I'm running right around 40 with my B&M FPR when the vacuum line is disconnected.
if it is a B&M, on the top, where the vacuum line connects, that is actually an adjusting screw. You turn it clockwise to turn up the fuel, and counter-clockwise to turn down the pressure.
B_Swapped93
Mar 25, 2013 10:35 AM
