is my clutch going?
Old Jan 24, 2006 | 04:47 PM
roundworldsobig's Avatar
Default is my clutch going?
in the morning i get in my car, put my foot on the clutch, then i start itup, but it does not turn over, then i would release the clutch pedal, press on it again and then it'll work. it'll work the first time 25% of the time but nowadays it's getting to be 3-4 times. it use to be just two times. what's wrong?! is my clutch going? it's a slippery clutch but oh well. just like to know.
Old Jan 24, 2006 | 04:51 PM
C1power's Avatar
Default Re: is my clutch going? (roundworldsobig)
just wondering....is your check engine light on?
Old Jan 24, 2006 | 06:32 PM
Sam92Teg's Avatar
Sounds more like your clutch interlock switch at the pedal arm.
Old Jan 24, 2006 | 06:48 PM
teg racer 877's Avatar
Default Re: is my clutch going? (Sam92Teg)
yea it sounds like the switch is going, not the clutch.
Old Jan 24, 2006 | 07:14 PM
kevb18crx's Avatar
switch would also being my geuss.
Old Jan 24, 2006 | 08:10 PM
check engine light is not on, where would this switch be located and how would i go about fixing this problem?
Old Jan 24, 2006 | 10:06 PM
Korch94's Avatar
look at the top of your pedal assembly (you will need a flashlight cause its crammed all the way up under the dash)...... basically at the top of the clutch pedal there is a part that depresses a pushbutton switch(its a plastic cylinder shaped thing about an inch and a half long)...the switch itself threads into the pedal assembly and is secured by a lock nut.
it may not be that the switch is bad but that it needs to be threaded further into the bracket to make better contact when you are pushing you clutch in.
put your car in NEUTRAL and crawl under there and push the button with your finger, then have a friend try and start the car. if it works every time then it is likely that you only have to adjust the switch rather than replace it
Old Jan 26, 2006 | 09:16 AM
mixster's Avatar
Default Re: is my clutch going? (Korch94)
its gotta be the switch. my ls was doing that for a couple of weeks and then wouldn't start at all. i knew the clutch was good cause i just replaced it like 4 months before. the car is a 94 and switches like to go out on older cars.
Steven Gilner
Sep 26, 2013 10:20 PM
96H4TCH
Jun 22, 2009 11:19 AM
zc89hatch
Feb 2, 2008 09:05 AM
3rdGteg
Nov 14, 2002 07:43 PM
