low idle at start upp
when i start my car when its warm outside...it idles REALLY low..almost turns off(and sometimes does) and i have to give it a little gas to help it out...any thought?
when was the last time you did a tune-up? Otherwise if its an older car you might have alot of junk built up in the throttle body housing and sensors. Seen both cause a low idle, otherwise check for a vacum leak.
heinrichranches
Oct 19, 2015 08:57 PM
