Swapping B18C internals
Old Jan 24, 2006 | 01:50 PM
kawaii05's Avatar
Default Swapping B18C internals
If this has been covered before someone please tell me what to search for! thanks
I have a B18C GSR short block that is damaged, I was wondering if I should just ditch this one and part it out for another short block. Or just buy a bare block and transfer all the internals over. What do I need to do if I just switch the internals over? (new bearings, machining the deck, etc) thanks!
Old Jan 24, 2006 | 02:24 PM
Ruben19's Avatar
what is the damage on your bock.
Crack sleeve, broken piston, rings, crank, bearings.
Old Jan 24, 2006 | 02:39 PM
kawaii05's Avatar
Default Re: (Ruben19)
all of the internals are ok, just outside pieces are broken off like the mount and stuff. I only have it because I got it for DIRT cheap. I bought it for the internals
Old Jan 24, 2006 | 05:16 PM
Ruben19's Avatar
yea!
you can use it on a ls-block or a other gsr block or type r.
ill be nice if you buy new bearings, seals, gaskets and rings.
which block are you getting
Old Jan 24, 2006 | 10:20 PM
kawaii05's Avatar
What do I need to do at the machine shop? I know I need new bearings. do they need to machine anything like the crank or the cylinders? I want to move the rods, pistons and crank over and of course use new bearings and rings. Is there anything else? thanks!
Old Jan 25, 2006 | 07:15 AM
Ruben19's Avatar
if you say that the shortblock is in good condition just get bearings and rings.
find your self a good block with good sleeves and bore it to 81.50mm. if is on your budget you can balance the crankshaft
Hatch Man
Engine Machining & Assembly
Aug 7, 2017 07:27 PM
Z0831xiz
Jan 2, 2015 03:34 AM
2 0 3
Northeast (Sales)
10
Mar 1, 2011 03:32 AM
Joeski99Si
Apr 10, 2009 11:36 AM
dayaftertomorrow
10
Apr 17, 2006 10:40 AM
