jdm engine question?
Old Jan 24, 2006 | 12:18 PM
hondajc19's Avatar
Default jdm engine question?
I replaced my 94 honda civic dx 1.5L engine with a jdm 1.5L engine the only difference is the new engine is a japanese engine what i want to know is they tell you to change everything on the engine basically your only suppose to use the block and replace everything else, but is it really neccasary or do they just tell you that for warrenty reasons and saftey reasons i read somewhere you have to change everything to get it to work in your car, but the warrenty only tells you to change everything for safety purposes.
Old Jan 24, 2006 | 12:25 PM
IHateJDM's Avatar
Default Re: jdm engine question? (hondajc19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajc19 &raquo;</TD></TR><TR><TD CLASS="quote">I replaced my 94 honda civic dx 1.5L engine with a jdm 1.5L engine the only difference is the new engine is a japanese engine what i want to know is they tell you to change everything on the engine basically your only suppose to use the block and replace everything else, but is it really neccasary or do they just tell you that for warrenty reasons and saftey reasons i read somewhere you have to change everything to get it to work in your car, but the warrenty only tells you to change everything for safety purposes.</TD></TR></TABLE>
1. use punctuation, one comma and one period isn't cutting it.
2. define 'everything'
Old Jan 24, 2006 | 02:08 PM
jax si's Avatar
Default Re: jdm engine question? (IHateJDM)
hmmm... learning how to type and use punctuation is not required on honda-tech.. but back on topic.. if you just ordered an engine. it is "generally" recommended to replace the oil and water pump. also you may want to replace head gasket and timing belt, and other gaskets just to have peice of mind. but it's your money... who cares?
Old Jan 24, 2006 | 02:27 PM
hondajc19's Avatar
Default Re: jdm engine question? (jax si)
didn't know this was a spelling class, so generally i don't have to replace anything unless i have to the engine should run fine either way.
Old Jan 24, 2006 | 02:45 PM
EG-SI(rII)'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jax si &raquo;</TD></TR><TR><TD CLASS="quote"> replace the oil and water pump. also you may want to replace head gasket and timing belt, and other gaskets just to have peice of mind. but it's your money... who cares? </TD></TR></TABLE>
other gaskets. ie: Exhaust manifold gasket, intake manifold gasket
P.S. Sorry. Some people on this forum, find it necessary to insult you. When they can't answer your questions.
P.P.S.(IHateJDM) Capitalize, hypocrite.
JDM Roolz!!!
Old Jan 24, 2006 | 03:48 PM
jax si's Avatar
Default Re: jdm engine question? (EG-SI(rII))
naw man i wasn't insulting you at all... i had the same questions when i got my swap initially.i'd just inspect it really good... maybe change the water pump for sure though... but just wait.. let this thread stick around for a bit and you'll get more opinions.. majority usually rules.
Old Jan 24, 2006 | 04:29 PM
99CivicSiBrian's Avatar
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jax si &raquo;</TD></TR><TR><TD CLASS="quote">hmmm... learning how to type and use punctuation is not required on honda-tech.. but back on topic.. if you just ordered an engine. it is "generally" recommended to replace the oil and water pump. also you may want to replace head gasket and timing belt, and other gaskets just to have peice of mind. but it's your money... who cares? </TD></TR></TABLE>
I'm jumping on the punctuation bandwagon here. Sorry, but it would help.
Anyway. With replacement engines, I always do the timing belt. Check the tensioner pulley for a bad bearing. Check the water pump for end-play or bad shaft bearing. If they feel like ****, replace them.
Since you have the valve cover off, use a feeler gauge and adjust the valve lapse. When you put the valve cover back on, use a new gasket. DON'T leave the cover off when installing the motor. You're bound to get some **** in there. Happened the last swap I did.
You'll also need your purge control selinoid for emissions and fuel economy. Just Zip-tie it to the firewall somewhere. Everything else should be intact.
B
Old Jan 24, 2006 | 04:36 PM
JdmLub's Avatar
Default Re: jdm engine question? (99CivicSiBrian)
when i did my swap to a JDM B16a, i switched my harness of my old motor.... since u switch 1.5 to a JDM 1.5 u shouldnt have to swtich mounts...... other then that i think that is bout it...
Old Jan 25, 2006 | 01:25 AM
74celicagt's Avatar
is it the engine importer/recycler that's telling you all this?
My guess is that they mean the EGR and other USDM emissions items so the JDM engine will be up to USDM emissions spec so the man is satisfied.
Old Jan 25, 2006 | 03:24 AM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajc19 &raquo;</TD></TR><TR><TD CLASS="quote">didn't know this was a spelling class, so generally i don't have to replace anything unless i have to the engine should run fine either way.</TD></TR></TABLE>
actually the instant it crosses the pacific ocean the motor is rendered useless and will not run at all. this occurs thanks to a law of intercontinental drift bullshit divide
Old Jan 25, 2006 | 05:45 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-SI(rII) &raquo;</TD></TR><TR><TD CLASS="quote">
JDM Roolz!!!</TD></TR></TABLE>
his question was too vague to answer, and lack of capitalization doesn't make it hard to understand. not knowing when he is starting and ending a sentence does. And JDM parts are the biggest rip-off in automotive parts history. I can't believe the markup people will pay for something JDM (motors not included).
if you want a basic list of parts that should be replaced for reliability reasons:
timing belt
water pump
dizzy cap and rotor
spark plugs and wires
fuel filter
If you're worried about passing emissions, that's a different story.
Old Jan 25, 2006 | 03:38 PM
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">his question was too vague to answer, and lack of capitalization doesn't make it hard to understand. not knowing when he is starting and ending a sentence does. And JDM parts are the biggest rip-off in automotive parts history. I can't believe the markup people will pay for something JDM (motors not included).
If you're worried about passing emissions, that's a different story.</TD></TR></TABLE>
There's an assload of markup on motors too. I think B16's go for like $300 or less in Japanland.
B
Old Jan 26, 2006 | 06:03 AM
hondajc19's Avatar
thanks i'm going to try to get the codes out of my computer becasue the engine is not working properly, and see what happens i'll keep you informed
dzvero
Honda Civic (2006 - 2015)
Apr 1, 2018 10:26 AM
crovard
Honda CR-V & Element
Apr 12, 2016 09:12 PM
Ben_si
Oct 7, 2005 06:07 AM
lilcasino
Oct 2, 2002 06:58 PM
