Q about timing belt change parts list and how often should i flush my tranny?
Old Jan 24, 2006 | 11:43 AM
businessmanph's Avatar
Default Q about timing belt change parts list and how often should i flush my tranny?
does anyone know of any good timing belt kits for 97 accord ex
where could i find cheap quality parts?
what else would i have to buy besides these parts for a timing belt repair
timing belt
T-belt tensioner
Balance Shaft Belts
Water Pumps
Power Steering Belt optional
Air Conditioning Compressor Belt optional
Valve Cover Gaskets
oil pump O-ring
cam seal
crank shaft seal
balancer shaft seal
balancer shaft seal RETAINER
T-belt tensioner
are these good sites to buy from
http://www.prostreetonline.com...t+Kit
http://www.manhonda.com/ap/ind...id=34
http://replacement.autopartswa...=true
what is the difference in pricing? is the most expensive part better?
should i try to get honda oem parts or does it matter?
how often should i flush my transmission? i recently got a CEL code and have to have it flushed. i'm guessing every 60k.
thanks in advance
Modified by businessmanph at 8:54 AM 1/25/2006
Modified by businessmanph at 8:55 AM 1/25/2006
Old Jan 24, 2006 | 12:44 PM
Thunder Cat's Avatar
oil pump O-ring
cam seal
crank shaft seal
valve cover gasket
balancer shaft seal AND balancer shaft seal RETAINER.
Old Jan 24, 2006 | 12:47 PM
alotawatts's Avatar
Default Re: Q about timing belt change parts list and how often should i flush my tranny? (businessmanph)
Cam and crank seals, T-belt tensioner.
San Leandro Honda west coast
Majestic Honda east coast
Old Jan 25, 2006 | 04:56 AM
Default Re: Q about timing belt change parts list and how often should i flush my tranny? (alotawatts)
i'm taking my car to the shop so do i really need all these parts?
if so is this list complete?
thanks a lot
timing belt
T-belt tensioner
Balance Shaft Belts
Water Pumps
Valve Cover Gaskets
oil pump O-ring
cam seal
crank shaft seal
balancer shaft seal
T-belt tensioner
Old Jan 25, 2006 | 08:21 AM
wait around a bit. i just noticed you're driving a 97 accord. i only know that for my 1990,it carries 4 belts. i dont know much about yours,but i'll bump this up for you
Old Jan 25, 2006 | 07:35 PM
Default Re: (Thunder Cat)
i thought 4th and 5th gen accords were very similar
Old Jan 27, 2006 | 05:33 PM
Default Re: (businessmanph)
thanks a lot
timing belt
T-belt tensioner
Balance Shaft Belts
Water Pumps
Valve Cover Gaskets
oil pump O-ring
cam seal
crank shaft seal
balancer shaft seal
T-belt tensioner
Old Jan 27, 2006 | 05:38 PM
BLKFLSH's Avatar
If you are taking it to a shop, they can get the parts cheaper than you can. So I doubt you would save any money buying the parts yourself.
PS: If you bring it to a Honda dealer they can probably wait until they take it all apart, then see what parts they need. Another shop can hardly do it that way because they don't have the parts in stock. But it will probably cost more at the dealer, so it's really a tuff choice.
Old Jan 28, 2006 | 07:31 AM
ricebike's Avatar
Default Re: (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">If you are taking it to a shop, they can get the parts cheaper than you can. So I doubt you would save any money buying the parts yourself.
yea, but the shops deal w/ aftermarket parts to keep their profit margins up while keeping the rates somewhat lower than dealer...
I bought Honda OEM parts from an online/ebay honda dealer on the west coast & have it delivered on the east coast... (prices were somewhat cheaper than dealers of NJ...)
from my list o parts, the only aftermarkets i woulda purchase were a felpro valve cover gasket set, ngk plugs, aftermarket drive belts (ps/ac/alt) but stuck to OEM when concerned w/ very important parts of the timing belt.
as seen on here: https://honda-tech.com/zerothread?id=1507250
I was going to take it to my independent shop, but they're soo booked... & wife needed the car , i ended up going to honda dealer instead. if you read my thread
Old Jan 28, 2006 | 07:41 AM
ricebike's Avatar
the last part is the same as the 1st... or do u mean balance shaft tensioner?
to add to your parts list:
plugs, if they haveta remove them during the job; they reinstall them w/out any additional fee, just like the drive belts.
prestone 5 year/100ooomile coolant... the yellow stuff. (who's still using green?)
oil/filter...optional since u can diy after they have done changing those oil seals...
as far as the CEL code: what was the actual code #? I didn't know it would light up to remind u to flush the auto transmission fluid...
did u goto autozone for a free obd II scan?
here's the list of codes:
http://www.troublecodes.net/honda/hondaobd2.shtml
let us know whatcha got!
Old Jan 28, 2006 | 08:05 AM
ricebike's Avatar
to add:
i usually drain/refill the auto trans fluid every other oil change or 2x a year... since the filter can't be reached like other cars... it's only like ~3 quarts every time you do it.
some on the board likes to use honda-specific only... others, like me, use regular mercon-dexron w/ no adverse effects
https://honda-tech.com/zerothread?id=1014116
https://honda-tech.com/zerothread?id=674913
https://honda-tech.com/zerothread?id=403847
https://honda-tech.com/zerothread?id=382406
https://honda-tech.com/zerothread?id=100983
bluelights81
Apr 13, 2014 10:36 PM
chandlorexia
Oct 12, 2012 06:40 AM
hometheaterman
Jun 4, 2010 11:17 AM
D21X
Aug 21, 2006 04:54 PM
gamblezhang
Mar 26, 2006 08:06 AM
