Whats my oil pressure suposed to be?
Old Jan 24, 2006 | 07:22 AM
ECHb18cR's Avatar
Default Whats my oil pressure suposed to be?
i have jdm itr motor and was wondering what my oil pressure was suposed to read at. I have a gauge that tells me its at about 72 psi @ around 4000 rpm... also...
my car tends to try and stall out...it idles pretty rough and the oil pressure drops but the car is idling at around 700-800 and still idling rough...i hope its not my oil pump ahhh help me...
E
Oh well i can still edit my posts ha
Modified by ECHb18cR at 1:14 PM 1/24/2006
Old Jan 24, 2006 | 07:35 AM
white rocket's Avatar
Default Re: Whats my oil pressure suposed to be? (ECHb18cR)
Idle should be around 20psi and WOT at around 80psi. A smaller oil filter like the HAMP will increase it by about 5psi. The JDM motor has higher compression so it may be a little higher but not much.
As for the stalling; do you have an aftermarket ECU or piggyback system?
Old Jan 24, 2006 | 08:02 AM
92TypeR's Avatar
FSAE
Default Re: Whats my oil pressure suposed to be? (white rocket)
Pressure should be between 20-25psi at idle when the car is at operating temps. WOT is between 75-80psi. Its been a while since I looked at my gauge, but the pressure relief valve should open at around 75psi when cruising...you'll see the pressure increase, then drop suddenly (~3-5psi) and hold steady.
Overall pressure will change with the size of the filter as Chris mentioned. Larger filters will reduce pressure, smaller will increase. These changes are not significant though, a difference of less than 10psi.
Old Jan 24, 2006 | 09:56 AM
ECHb18cR's Avatar
yeah i have a vafc ---its a 94 civic cx hatch with jdm itr...i just bought it a week and 2 days ago!
and i cant post more than 5 a day how do i change this crap ha
Old Jan 24, 2006 | 10:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECHb18cR &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have a vafc ---its a 94 civic cx hatch with jdm itr...i just bought it a week and 2 days ago!</TD></TR></TABLE>
The tune may be your problem. Not sure though. Hybrid forum may be able to answer that better for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECHb18cR &raquo;</TD></TR><TR><TD CLASS="quote">and i cant post more than 5 a day how do i change this crap ha</TD></TR></TABLE>
This is in place to prevent post whoring for n00bies. You have to earn the right to post *****
Old Jan 24, 2006 | 10:12 AM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">
This is in place to prevent post whoring for n00bies. You have to earn the right to post ***** </TD></TR></TABLE>
LOL
trulyshavedintegra
Dec 9, 2012 05:06 AM
ProjectBB6
Sep 16, 2009 02:18 PM
88da3
Nov 21, 2005 10:31 AM
Harassing Herbs
Mar 16, 2004 05:09 PM
IntegD
Jan 8, 2003 09:31 PM
