What Cams to use?! I searched!
Old Jan 23, 2006 | 06:04 PM
Ludeguy2486's Avatar
Default What Cams to use?! I searched!
I know there have been previous threads on here as to what cams to run on the h22 but i cant seem to find them. Anyway... trying to figure out what cams to run on my jdm h22... its got a header, hi flow cat, exhaust, intake, fuel rail, nitrous, and a bunch of other little goodies. I'd rather not do a valve train right now and I dont plan on boosting. (at least not for a long time) Just wondering if someone could point me in the right direction...thanks guys
Old Jan 23, 2006 | 06:29 PM
hu's Avatar
hu
Type S cams. Why don't you want to upgrade your valvetrain? If you upgrade the valvetrain you can go with Skunk2 stage 2 cams.
Old Jan 23, 2006 | 07:07 PM
The Weather Man's Avatar
There's not much you can do without a valvetrain - maybe skunk2 stageI and crower stage I..............or type s ofcourse.
Old Jan 23, 2006 | 07:20 PM
Missing Gears's Avatar
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">Type S cams. Why don't you want to upgrade your valvetrain? If you upgrade the valvetrain you can go with Skunk2 stage 2 cams. </TD></TR></TABLE>
i wouldnt recommend skunk stg.2s on stock bottom end.
2 reasons: not enough comp. to take full advantage of them and also
very tight clearances, skunk will tell you this if you bother to call them.
i have tried several times and they work ok (same ets. as s cams) more peak and alot less midrange. until i pulled the head and noticed the grooves in the valve releaves. (more than once) skunk stg 2s have the highest lift of any h series cam. skunk does not recommend running them w/ stock pistons. of course they dont tell you that until you call them and speak to one of the techs off the record.
go w/ the s cams and keep your stock valvetrain
Old Jan 23, 2006 | 09:30 PM
Nipsey Hussle's Avatar
Default Re: (Missing Gears)
Thanks for the clear up on this but would the stage ones skunk2 crower ect be the equivalent to Type S cam's or better
Old Jan 23, 2006 | 10:13 PM
SilverPanda's Avatar
Default Re: (Negrodamus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Negrodamus &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the clear up on this but would the stage ones skunk2 crower ect be the equivalent to Type S cam's or better</TD></TR></TABLE>
they might be a little better, but if you arent gonna touch the valvetrain or the bottom end, i'd go with type s cams.
Old Jan 23, 2006 | 10:47 PM
Sick'Lude's Avatar
Default Re: What Cams to use?! I searched! (Ludeguy2486)
Call me a noob but whateva..how do u know what engine is a typeS..what's the code H22a1 H22a H22a4??...what engine is a typeS
Old Jan 23, 2006 | 11:06 PM
hu's Avatar
hu
The Type S engine was available on JDM Preludes. It has higher compression pistons and better cams.
Old Jan 23, 2006 | 11:13 PM
Sick'Lude's Avatar
Default Re: (hu)
Well I have an H22a its a jdm engine???is there a code of any type??
Old Jan 23, 2006 | 11:18 PM
hu's Avatar
hu
I have no idea what the type S code is. IIRC, the USDM H22 has 10.1 compression. The JDM H22 has 10.6 compression. The JDM H22 Type S has 11.1 compression. Did you buy the car with the jdm engine in it? Check your paperwork. If it was a type S, they would have made it clear.
Old Jan 24, 2006 | 12:51 AM
Sick'Lude's Avatar
Does any 1 else know..cus iam wanting the typeS I'M and cams..but I don't wanna buy em' if my H22a is already jdm typeS?!
Old Jan 24, 2006 | 04:36 AM
PirateMcFred's Avatar
Default Re: What Cams to use?! I searched! (Sick'Lude)
This thread should have been posted in the 'official camshaft thread':
https://honda-tech.com/zerothread?id=939641
It is unlikely that you got a Type-S accidentally. And BTW the Type-S has ATTS. Unless you have an SH lude then you probably don't have one unless you did some custom fab.
Pirate
Kiniku Chunks!!!
Feb 6, 2007 07:30 PM
codeh22a4
Sep 21, 2004 02:27 PM
Single MOBB
Mar 1, 2004 11:53 PM
rocco
33
Feb 16, 2004 01:14 PM
216.226.142.95:27016
33
Jun 17, 2003 09:23 AM
