Power; windows, locks, mirror - EG
i bought a d/s and p/s complete doors. it has all the essential parts to convert my hatch to power but i dont have the in between harness. is there a way that i can wire it up myself without using the harness itself? or will i have to get the harness from a ex?
short answer is no.... this has been covered in several threads, most are linked in this thread, your best friend for your eg: https://honda-tech.com/zerothread?id=642479
I got the whole harness, so when I install mine, I'll be doing the whole swap, but the dash has to come out for that.... basically you'll just have to run power to the doors, and ground all the ish out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 »</TD></TR><TR><TD CLASS="quote">i've checked the guides, an EK was able to do this without the floor harness so i thought it would be the same for an EG.</TD></TR></TABLE>
well, when I pulled the harness out of my coupe, I believe the doors fed into the harness that went behind the dash and the floor harness feeds out of that. I don't think that it's plug and play without a lot of work. I believe it all runs from the doors into the dash harness, and to the fuse box, but you may want to get someone to verify this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 »</TD></TR><TR><TD CLASS="quote">i had plans to use the diagram on here
http://repo.jackmoves.com/albun42
but the website is down
apparently not dead, just hidden....
http://repo.jackmoves.com/v/erik/albun31/albun42/
</TD></TR></TABLE>apparently not dead, just hidden....
DJNauTicz
Feb 19, 2007 10:06 AM
DJNauTicz
May 12, 2005 12:35 PM
