axle bolt....Help
Hey guys, I am trying to get the bolt from the knucle that holds the axle in place off. I tried heating it with Propane, a Johnson Bar, WD-40 and the fucken thing wont come off. Is there a better fuel that'll heat it up better or what should i do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8 h0! »</TD></TR><TR><TD CLASS="quote">get a bigger pry bar and hammer.
Pry bar???
</TD></TR></TABLE>Pry bar???
the big 32mm bitch?
1 word. impact
u need banging force not pressure force to snap that bitch off.
o yeah also, on one car i did i had to remove the entire upper control arm and hub and ****, i never did get it outta the hub. i had to buy another.
1 word. impact
You want to make sure you have completely uncrimped the nut.
If it is still bent in it will be very difficult to remove.
Other than that, a big breaker bar and my body weight is how I got mine off.
hondaboy9506
34
Nov 1, 2010 05:50 AM
RCautoworks
48
Nov 27, 2006 12:26 AM
NSfit
34
Nov 6, 2006 03:03 PM
