Motor swap or re-build, what would you do??
Old Jan 23, 2006 | 03:17 PM
zx2gotboost's Avatar
Default Motor swap or re-build, what would you do??
Motor: D15B7 SOHC NON VTEC
My rings are shot, i think, I use about 4 quarts of oil about every 2 weeks. I posted my compression tests on another thread.
Anyway, im pretty sure Its my rings and I need your advice.
Here are my options
D15B Vtec 450 bux plus shipping osacamotorsports
OR
NEW rings, Rod bearings, hone cylinders, re-silicone oil pan, new head gasket (take head off) -- unless the D16y8 head gasket that I have on it is re-useable.
OR
I have a Stock D16z6 (del sol) Vtec block in my shop, that Had Rod knock Due to a chick not putting oil in the car. (so Id need new rod bearings,? What else? ) Need to rebuild, What all is needed if it had rod knock?
Since the car is daily driven it would be alot easier to rebuild the block that I have (D16Z6) Honda del sol motor SOHC VTEC
So what would you do? Re-build the block or JDM motor?
BTW, If I do decinde to re-build the Vtec bloack D16Z6 is there any mods that I have to do to put my NON-VTEC Head on it? (I want to use my non vtec head cuz its BRAND NEW ~~ 300 miles on it, and I ported the ports on exhaust and intake sides.
Modified by zx2gotboost at 7:18 PM 1/24/2006
Old Jan 24, 2006 | 09:44 AM
SOL Food's Avatar
d15b VTEC swap.
Old Jan 24, 2006 | 09:58 AM
africanqueen's Avatar
Default Re: (MARSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MARSH &raquo;</TD></TR><TR><TD CLASS="quote">d15b VTEC swap.</TD></TR></TABLE>
x2
Old Jan 24, 2006 | 10:02 AM
hondaless's Avatar
Default Re: (africanqueen)
rebuild the bottom end with a slightly higher compression piston...you'll get more power out of it and you know the motor would be all new. With the JDM ones you get the luck of the draw. I had 2 ZC motors one looked great the othe looked like crap but ran ok.
Old Jan 24, 2006 | 05:57 PM
Default Re: (hondaless)
well my thing is:
D15B vtec=450 + shipping, probably 470 to 500 total. + 1 possibly 2 hours down time
Rod bearings ($40.00-60.00), piston rings($30.00-70.00),silicone (oil pan), brake parts cleaner or honing oil(5.00), Headgasket (D16y8 45.00) or stock (d15b7 30.00), + 5 hours+ down time = ? 300 bux or so.
Old Jan 24, 2006 | 06:02 PM
bmiller17's Avatar
Default Re: Motor swap or re-build, what would you do?? (zx2gotboost)
x3
Old Jan 24, 2006 | 06:10 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Since you said your D15B7 head is basically new, I say build the Z6 bottom end you have lying around.
Old Jan 24, 2006 | 06:16 PM
Default Re: Motor swap or re-build, what would you do?? (d15singlecammer)
Well, it needs rebuilt... All I know is it had rod knock, so i replace the rod bearings, and thats it? I may have to drop the crank, have it turned or whatever, new main bearings, hone the cylinders? Im not sure.
So far we have rebuild motor 1 / D15B vtec 3
Now Im thining my head is ****, the ticking got loud.
And in second gear, the car like hesitates from what 2K-4K then it smooths out. Mabey thats the blow by problem? Or mabey thats cuz the head is ported? or mabey thats cuz I have no muffler? mabey thats cuz the rings are shot? But why only in second gear ? it smooths out after like 4 or 5 K ( don't have a tach)
Old Jan 24, 2006 | 07:16 PM
Anyone know places I can get Motors? someone said Osaka motorsports? or some other site...
Rebuild D16Z6(non vtec head) or buy D15B non vtec or vtec ?
Old Feb 1, 2006 | 09:49 AM
DC2SIR-G's Avatar
* B A N N E D *
how bout plan D B18C swap
Old Feb 1, 2006 | 10:02 AM
tallyturbo's Avatar
Default Re: Motor swap or re-build, what would you do?? (tekneshum2)
i think for them to ship your engine it is going to cost more than what you think. where would it be coming from?
Old Feb 1, 2006 | 10:06 AM
d16vtecx's Avatar
d15 vtec
better than a z6 anyways
Old Feb 1, 2006 | 10:21 AM
hondafan62269's Avatar
d15b, less downtime. Rebuild=$$$. With cost for rebuild and parts, you'd be very close to just buying a d15b. Plus you could sell what ever is salavagable from your motor. You may brake even or make a profit.
aeon117
Jun 24, 2016 01:05 AM
Nisif
Feb 18, 2009 06:55 PM
teal_dx
Aug 28, 2007 11:13 AM
95droppedhatch
23
Jan 8, 2007 06:11 PM
zx2gotboost
10
Jan 13, 2006 06:47 PM
