Making a stronger electrical connection?
Old Jan 23, 2006 | 03:03 PM
SNsLude's Avatar
Default Making a stronger electrical connection?
The connections on my ICM have either poor contact or they are just simply loose. Any ways to make this connection stronger other than crimping it? And I dont think I can stick copper anywhere... are there any sprays or gellies I could use?
Old Jan 23, 2006 | 03:09 PM
mgags7's Avatar
what do you mean, the connections where?? how did you measure that they have bad connections??
Old Jan 23, 2006 | 03:18 PM
SNsLude's Avatar
Default Re: (mgags7)
The ICM in the distributor has those 4 connections that plug onto it... I know they either are loose or have poor contact becuase when I crimped them down, it temproarily fixed the problem I was having. But I guess with driving long and the bumpiness, it makes the connections come loose again and my problems arise again.
edit: and wow, Last time I was on here, you only had like 600 -700 posts... come a long way ^
Old Jan 23, 2006 | 05:03 PM
Jos3ph's Avatar
Default Re: (SNsLude)
Whenever there is a loose connection between two wires, i always solder the two points together then neatly wrap it with some electrical tape.
Old Jan 23, 2006 | 09:27 PM
ed_1's Avatar
Default Re: (Jos3ph)
Well there's your problem, you crimp them, especially on something critical like the distributor, solder them, and heat shrink them is better than electrical tape, cause it doesn't come off with heat.
Old Jan 23, 2006 | 11:49 PM
SNsLude's Avatar
Default Re: (ed_1)
... Okay, the ICM has 4 metal prongs that stick out from it (part #8 below).
The connections that I'm talking about slip over these 4 prongs. So theres nothing I can solder or heatshrink, at least by visual observation... if you guys get what i mean? Unless you mean by cutting off the butts, splicing the wire, and solder the actual wire tip straight to the contacts...
Old Jan 24, 2006 | 07:05 AM
mgags7's Avatar
no youre not gonna want to soldier those, you would fry the icm....maybe just clean them very well, and then bend down the edges so they slip on tighter...
i cant believe those are jiggling off...i have never seen that before...
Old Jan 24, 2006 | 03:19 PM
SNsLude's Avatar
Ah, I see... Thanks... so soldering is out... when you say bend the edges... you mean the edges of the ICM terminals right? Yah I tried to even clamp down the connections quite hard, but they still jiggle.
Old Jan 24, 2006 | 04:11 PM
SNsLude's Avatar
Sorry, to make things clearer if I confused any of you...
These are what the terminals look like... and they slip over those metal things that the blue arrow is pointing too... I tried clamping and it just doesn't seem to do the trick =/
Old Jan 24, 2006 | 04:34 PM
danerr's Avatar
dude just solder them, you wont fry it seriously. just solder as quickly as possible. the dist was built to be subjected to heat.
Old Jan 24, 2006 | 07:06 PM
mgags7's Avatar
you dont want to soldier those....they dont need to be soldiered....
just tighten up the clips, squeeze them as much as you can but let them still fit on....
Old Jan 25, 2006 | 07:09 AM
prelittlelude's Avatar
Default Re: Making a stronger electrical connection? (SNsLude)
yeah just slip the clips over and then give them a little squeeze with some pliers.
Old Jan 25, 2006 | 08:17 AM
577HondaPrelude's Avatar
Default Re: Making a stronger electrical connection? (prelittlelude)
use some pliers and squeeze the plugs down a little, while not on the terminals. If you do it right they will fit real tight, however don't go too far or they will not go on.
Old Jan 25, 2006 | 08:45 AM
Hawkze_2.3's Avatar
Default Re: Making a stronger electrical connection? (577HondaPrelude)
You could also use a little di-electric grease on them which will help make a better connection.
Old Jan 25, 2006 | 12:10 PM
Jagan'92's Avatar
Default Re: Making a stronger electrical connection? (Hawkze_2.3)
If you really wanted to use solder, you could put a solder ball onto the male terminals so that it is larger and easier to retain. It wouldn't be a permanent connection either, which is why soldering is a bad idea.
Another option is to replace that female connector with a new one. The dielectric grease won't hurt the connection, but it might make them slip off easier.
redricer
Jul 25, 2007 07:19 AM
LoseRPunKx182
Jun 5, 2005 02:47 PM
mini-v-si
Mar 17, 2004 06:29 AM
Jon5240
Oct 25, 2003 08:35 PM
austrian type-R
Jul 25, 2002 01:40 AM
