How do I remove the cable from my accelerator pedal?
Old Jan 23, 2006 | 10:09 AM
MonkeyPuzzle's Avatar
Default How do I remove the cable from my accelerator pedal?
Please I need help, and yes I have searched but found no actual answers.
I need to remove the brake and accelerator assembly so I can replace them after I did a auto-manual swap.
I have just having trouble getting the accelerator cable removed from the pedal.
It appears to be held in by a white clip, does anyone know how to remove this white clip?
Old Jan 23, 2006 | 10:10 AM
igo4bmx's Avatar
i think you have to rotate the cable 90 degrees
Old Jan 23, 2006 | 10:19 AM
Default Re: (igo4bmx)
thanks, I shall give this a go.
Anyother ideas while I go try that one?
Old Jan 23, 2006 | 10:22 AM
Luserkid's Avatar
Default Re: (MonkeyPuzzle)
its a clip. On the back of the white theres a push in on both sides. Push one in while you pull and the whole thing will come out.
Old Jan 23, 2006 | 10:32 AM
IVI's Avatar
IVI
Default Re: (Luserkid)
stick your head under there. put some slack on the cable, it helps if you disconnect it from the throttle body first. once there is sufficient slack it is similiar to how it goes to the throttle body.
if you removed it you will know. if you dont remove it look at how it goes in the throttle body for reference.
its very simple.
Old Jan 23, 2006 | 10:56 AM
igo4bmx's Avatar
sorry i was thinking cruise control now...
Old Jan 25, 2006 | 11:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">its a clip. On the back of the white theres a push in on both sides. Push one in while you pull and the whole thing will come out. </TD></TR></TABLE>
This man is correct.
I took a picture to help others, I will post it when I get home.
Old Jan 25, 2006 | 11:11 AM
MrMike's Avatar
If your doing a auto-5speed conversion, you don't need to remove the whole gas and brake pedal assembly. just change the brake pedal. Its a big 14mm or 17mm bolt at the top of the pedal i think. if you change the whole thing including the gas pedal you'll need a 5speed throttle cable. auto and 5speed are different.
Old Jan 25, 2006 | 12:09 PM
Default Re: (MrMike)
conversion is done, cable is good.
Also needed to change out the accelerator because I needed the bracket with the cruise control cable to attach to.
92SiHatchie
16
Nov 2, 2018 02:56 PM
bk7794
May 29, 2011 06:08 AM
fcjohnny
May 21, 2009 03:48 PM
delguiner
Jun 15, 2004 12:08 PM
Grimm
Dec 1, 2003 05:41 AM
