blinkers and horn dont work
Old Jan 23, 2006 | 08:33 AM
INTEGRA_boy's Avatar
Default blinkers and horn dont work
so my bro's R has been turbo for a while and we can figure out why is front blinkers and horn wont work..we've thought a lot about why they arent and we cant figure it out..why is this?
Old Jan 23, 2006 | 09:08 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: blinkers and horn dont work (INTEGRA_boy)
I dont know why you cant. But I would check you fuses. Next time when you need an answer to a question, speak clearly and give us ALL the information.
Old Jan 23, 2006 | 09:33 AM
len's Avatar
len
Next to the Radiator Coolant Overflow tank should be a separate tank for the Blinkers. Check to make sure there is enough fluid in there.
Old Jan 23, 2006 | 09:42 AM
KetteringITR's Avatar
Default Re: blinkers and horn dont work (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">Next to the Radiator Coolant Overflow tank should be a separate tank for the Blinkers. Check to make sure there is enough fluid in there.</TD></TR></TABLE>
Funny, but seriously he's just asking for help so help him. Although it did make me smile. Fuses would be the first thing id check and go from there. GL.
Old Jan 23, 2006 | 09:50 AM
Dave_B's Avatar
Len, on that note could you get me a part number on a muffler bearing for a 00 ITR? TIA.
As for the original poster, check fuses. Also has the air bag ever blown? Have you ever had the steering wheel removed? If all the fuses are fine, check the wire for the horn, or the return for the blinker.
Old Jan 23, 2006 | 12:30 PM
Default Re: blinkers and horn dont work (Dave_B)
the car has never been wrecked and nor has the airbag deployed..but ill check the fuses for him when i get home
Old Jan 23, 2006 | 12:41 PM
nsxtasy's Avatar
H-T Order of Merit
Check the bulbs in the blinkers, too...
Old Jan 23, 2006 | 01:06 PM
Kavehman's Avatar
im pretty sure u have kicked a ground loose, or blowna fuse. Check all the grounding points an the fuses
Old Jan 23, 2006 | 01:13 PM
Default Re: (Kavehman)
well we had to remove the corner lights to get the front bumber off for the FMIC. so we might have blown a fuse there..like i said ill look
Old Jan 23, 2006 | 01:24 PM
len's Avatar
len
LoL...I'm just having fun. Don't mind me. There is a Turn Signal and Hazard Relay (FR-3309 on Relay) in the driver side kick panel that controls the turn signals and I've seen a similar incidence where this part goes bad and affects the horn also.
Old Jan 24, 2006 | 01:23 AM
DC5RK20A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">LoL...I'm just having fun. Don't mind me. There is a Turn Signal and Hazard Relay (FR-3309 on Relay) in the driver side kick panel that controls the turn signals and I've seen a similar incidence where this part goes bad and affects the horn also.</TD></TR></TABLE>
Do you do this to customers at the dealership? hahaha that would be funny to see the look on their faces, because I am sure some people might smile, nod and actually look for this extra reservoir to put in winker fluid.
Old Jan 24, 2006 | 06:50 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: blinkers and horn dont work (DC5RK20A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5RK20A &raquo;</TD></TR><TR><TD CLASS="quote">I am sure some people might smile, nod and actually look for this extra reservoir to put in winker fluid.</TD></TR></TABLE>
At the dealership, they call it "****** fluid".
Old Jan 24, 2006 | 12:34 PM
Default Re: blinkers and horn dont work (nsxtasy)
k..ill check that kick panel..cuz no fuses are burnt out right now
DC4 ENTHUSIAST
Oct 30, 2008 08:50 PM
ThA IntegrA HI
Apr 7, 2007 09:43 AM
ck123
Jul 21, 2006 08:33 PM
DFW
14
Apr 17, 2006 09:51 PM
96Integ
Feb 25, 2002 11:46 PM
