Is it alright to....
Old Feb 25, 2002 | 08:35 AM
96Integ's Avatar
Default Is it alright to....
Is it alright to drive around without my coolant reserve tank?? Mine broke and I can't get a new one untill next monday. I'm going to be driving around with some coolant in my car and will check the level in the radiator just to make sure. I'm sure it will be fine I just want to double check.
Old Feb 25, 2002 | 09:38 AM
BlowOff's Avatar
New User
Default Re: Is it alright to.... (96Integ)
I would not do it. The reserve tank is there for multiple purposes. One purpose is for the hot (expanded) coolant to over flow into. If you remove the tank, the expanded hot coolant will have nowhere to go and could (if you plugged up the little hose really good) explode the radiator.
Old Feb 25, 2002 | 09:55 AM
betsuni's Avatar
i wouldn't do it if i were you...
get a coolant reservoir tank.....
Old Feb 25, 2002 | 10:54 AM
threatcon13's Avatar
New User
Default Re: Is it alright to.... (betsuni)
use a cherry coke bottle in the meantime
Old Feb 25, 2002 | 12:53 PM
96Integ's Avatar
Default Re: Is it alright to.... (ALLMOTORDC2)
hmm, I guess i could use something in place of the tank. The tube isn't plugged and my local dealer can't get it into next monday and the junkyards don't have any either. Do they sell unversal ones at discount or pep boys??
Old Feb 25, 2002 | 01:48 PM
Acura_I-RS's Avatar
i am just using a mountain dew bottle, cuz mine some how un hooked itself , and ended up right on my exhaust manifold, and melted completely, i was scared, they i grabbed the dew bottle in my hand, and cut a hole in the cap just big enough for the hose, and it actually works really good
Old Feb 25, 2002 | 01:56 PM
96Integ's Avatar
Default Re: Is it alright to.... (Acura_I-RS)
yeah that is what happened to me, but i put the tank on the header while i was messing with my intake and i forget to put it back Well i was driving later and i noticed a funny smell and then i noticed some smoke coming from the hood. i pulled over poped the hood and the thing was on fire!! luckily there wasn't much damaged.
Old Feb 25, 2002 | 02:28 PM
samagon's Avatar
like others say, just get a 24oz bottle of your favorite drink, and when you finnish it, zip tie it to your radiator support and stick the hoze in there.
[Modified by samagon, 5:28 PM 2/25/2002]
Old Feb 25, 2002 | 06:24 PM
96Integ's Avatar
Default Re: Is it alright to.... (samagon)
Alright thanks for all the replies, now should I put coolant in there or should I just leave it be?
Old Feb 25, 2002 | 10:20 PM
Calavera's Avatar
This very samething happened to a friend of mine too. Weird...
He actually drove around a little without it and it seemed to be fine...but I wouldn't recommend to anyone to do this.
Btw, this plastic tank will cost you something like $50 from the dealership I think.
Old Feb 25, 2002 | 11:42 PM
sackdz's Avatar
Hahaa exact same thing happened to me. You can drive around without no problem, just make sure the tube drains on the ground so you don't get coolant everywhere
it won't cause an increase in pressure (whoever said that), just check your fluid level from time to time, mine never needed any. After several months I've finally recieved a new one, liek $35 from acura.
Old Feb 25, 2002 | 11:46 PM
nfn15037's Avatar
Exact same thing i did. I oiled my K&N, and i was like, WTF is that smell? Maybe i oiled it too much. Then i see lil whisps of smoke, and im like ,hmmm, open the hood, OH $HIT! Im a dumbass Now i have a tank from an accord that doesnt fit right, but does the job for $5 from the junkyard. ALso, i drove around for MONTHS without a overflow, just watch the radiator level.
[Modified by nfn15037, 12:47 AM 2/26/2002]
[Modified by nfn15037, 12:48 AM 2/26/2002]
hondalove888
Jun 9, 2008 06:22 PM
CXtypeR
Jan 26, 2007 08:10 PM
tsmith0819
Jan 15, 2007 01:20 PM
ATS*Mark
Dec 20, 2003 09:37 PM
intekragsr
Oct 28, 2002 05:25 PM
