would it be safe if i reinforce my manifold by means of arc welding...stick welding?????
Old Jan 22, 2006 | 10:10 PM
eg2phosizzle's Avatar
Default would it be safe if i reinforce my manifold by means of arc welding...stick welding?????
i was thinking bout reinforcing my turbo mani. because i've heard some bads things about them cracking....so what would you suggest doin???i have an arc welder...so is it possible with the arc???
Old Jan 22, 2006 | 10:48 PM
R6E6I6D's Avatar
Default Re: would it be safe if i reinforce my manifold by means of arc welding...stick welding????? (eg2pho
wait till it cracks ha,
Old Jan 22, 2006 | 11:33 PM
*Boostwerks*'s Avatar
depends obviously what manifold you infact have. If you have one that is in any way shape, or form like the one pictured above...Please throw it in the trash, and sew them for damages...
Old Jan 23, 2006 | 05:23 AM
CRXDrew's Avatar
Yea once you start welding on those SSAC mani's its generally down hill from there. The material around the welds will keep cracking until you have nothing left but a mani made of welds
Old Jan 23, 2006 | 07:08 AM
ManBearPig4silly's Avatar
No it wont work very well at all. Use it as a paperweight and it will always remind you of the lesson you have learned. SSAC is the worst manifold on the face of the earth.
on a side note the hell is up with the sponsored link on the word turbo?
Old Jan 23, 2006 | 09:38 AM
.dave's Avatar
i HAS questions ?
Default Re: (I4sillypwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">on a side note the hell is up with the sponsored link on the word turbo?</TD></TR></TABLE>
Are you talking about green underlined text with links?
Old Jan 23, 2006 | 10:38 AM
RCautoworks's Avatar
Default Re: (CRXDrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">Yea once you start welding on those SSAC mani's its generally down hill from there. The material around the welds will keep cracking until you have nothing left but a mani made of welds </TD></TR></TABLE>
How do you know that Drew
Old Jan 23, 2006 | 07:46 PM
R6E6I6D's Avatar
Default Re: (90blackcrx)
nah, u think? i have been boosting since the repair and seem to have had zero cracks/problems...
Idk, that manifold is gunna stay, I am building another motor and thats where my money goes
Old Jan 23, 2006 | 07:51 PM
discrete's Avatar
If it's an area that doesnt get too hot, why not?
It's not like you could make it much worse.
Old Jan 23, 2006 | 11:43 PM
R6E6I6D's Avatar
Default Re: (discrete)
good point, if its temporary its still a better fix than no fix at all
Old Jan 24, 2006 | 07:50 AM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2phosizzle &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking bout reinforcing my turbo mani. because i've heard some bads things about them cracking....so what would you suggest doin???i have an arc welder...so is it possible with the arc???</TD></TR></TABLE>
Do NOT reinforce the manifold. Reinforce the turbo and wastegate mounts. If you can mount the turbo in such a way that you can remove the manifold without having to remove the turbo, and you have a flex joint in the exhaust, then you will never have a problem with the manifold cracking, even if it is a SSAC.
Old Jan 24, 2006 | 09:37 AM
Default Re: (R6E6I6D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6E6I6D &raquo;</TD></TR><TR><TD CLASS="quote">nah, u think? i have been boosting since the repair and seem to have had zero cracks/problems...
Idk, that manifold is gunna stay, I am building another motor and thats where my money goes </TD></TR></TABLE>
I was joking around, me and Drew have a friend who was using an ss autoshits manifold, it cracked about 30 times.
koulaid
Oct 21, 2008 08:17 AM
fabnewb
Welding / Fabrication
36
Apr 10, 2006 09:30 AM
lkailburn
Jul 31, 2005 11:57 AM
Blindstuff
Oct 5, 2004 06:33 PM
egturbo
Jun 13, 2004 07:06 PM
