which piston should I pick
go with ctr pistons
higher compression
it makes 10:8.1 in a b16b and with a gsr head will probably go 11:1
itr on a gsr around 10:6.1 or a lil more.
defenetly ctr pistons they r better
higher compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">go with ctr pistons
higher compression
defenetly ctr pistons they r better</TD></TR></TABLE>
you mean 10.8:1 and 10.6:1?
ten point eight TO one ratio...
ten point six TO one ratio
higher compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dayaftertomorrow »</TD></TR><TR><TD CLASS="quote">So higher compression means more horse power? Also what is the red line if I change to ctr pistions</TD></TR></TABLE>
rev limit depends on what type of valve train you have...also if your cams make the power at high rpm's. but yes, higher compression with agressive cams= BIG POWER!
I actually happen to have a set of brand new oem ctr standard bore pistons/rings/wrist pins for sale
PM me if your interested
duRritztiNy
35
May 16, 2003 10:36 PM
