Getting del sol need motor advice.......
Old Jan 22, 2006 | 07:33 PM
Aztec Sol's Avatar
Default Getting del sol need motor advice.......
ok its the s del sol witht he d 16y8 i think. now heres my problem is that i live in las vegas and i have smog laws over here. but like any tunner i want more power. i would like to at some point put a turbo on it and may be a little shot of Nos just for fun. But my real question here is what sohc vtec could i put in with out worrie or somg if any. or should i just stay with my motor that i have in it now and tune it. plz help.
future plans
c.a.i
turbo
high flow cat (carb legal)
exhaust
short throw shifter
lowering springs
tokico illumina shocks (5-way abjustable)
upper and lower strut bars rear and front
and my more lol to many to name
Old Jan 22, 2006 | 11:13 PM
Aztec Sol's Avatar
Default Re: Getting del sol need motor advice....... (Aztec Sol)
BUMB
Old Jan 23, 2006 | 12:20 AM
salesmonkey's Avatar
most turbos are not for smog unless u get a cheap kit running 5 psi
Old Jan 23, 2006 | 01:10 AM
Aztec Sol's Avatar
Default Re: Getting del sol need motor advice....... (salesmonkey)
ok so up to what motor can i put in and be safe if any
Old Jan 23, 2006 | 01:27 AM
TK-4004's Avatar
to find out more about d-series turboing....go here http://www.turbod16.com/
personally i run n/a, so i dont know much about turbos....but im pretty sure that any turbo you put in will not pass smog unless it is a carb exempt turbo kit (i.e. greddy, etc).
Old Jan 23, 2006 | 04:59 AM
SpydiR's Avatar
Default Re: Getting del sol need motor advice....... (TK-4004)
turbo or c.a.i., not both
edit: the greddy kit is CARB legal, though I wouldn't worry about it unless you're in cali.
Old Jan 23, 2006 | 05:52 AM
IHateJDM's Avatar
Default Re: Getting del sol need motor advice....... (SpydiR)
what year sol? if its the s trim, its a d15 for 93-94 and d16 non-vtec for 95-97. the si's got the z6 or y8 vtec motor.
Old Jan 23, 2006 | 06:41 AM
Crasian's Avatar
keep the motor u have now, its great
Old Jan 23, 2006 | 07:57 AM
del Slo SiR's Avatar
get a del Sol Si, not S if you can...
Old Jan 23, 2006 | 01:03 PM
Aztec Sol's Avatar
Default Re: Getting del sol need motor advice....... (IHateJDM)
ok ill check to see what motor it has in it and post. i know its a d16 just have to look at the other letters or numbers. and thanks for the link to guys
Old Jan 23, 2006 | 02:38 PM
J-TeK's Avatar
hey i got a del sol wit intgra front end wit H22 motor swap u kan chek itout on my site at http://www.Xanga.com/onexjourney.com
Old Jan 23, 2006 | 10:34 PM
Aztec Sol's Avatar
ok took a look at the motor to day its a d16z6 . ill post some pics later if i can. so is this a good motor to start with or i should say to boost. thanks
Old Jan 24, 2006 | 08:53 AM
SOL Food's Avatar
if you have a d16z6 then you have an Si model Del Sol.
either that or the previous owner swapped that motor into your S model.
either way you're gonna have to swap in a motor that's NEWER than than the chassis of your car (i.e. - if you have a 93-95 then you must get a motor that's 96+).
i'd either get an b18b or a d16y8 from the 96+ Civic EX's and boost that.
Old Jan 24, 2006 | 10:10 AM
IHateJDM's Avatar
Default Re: (MARSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MARSH &raquo;</TD></TR><TR><TD CLASS="quote">i'd either get an b18b or a d16y8 from the 96+ Civic EX's and boost that.</TD></TR></TABLE>
why swap out a z6 for a y8?
Old Jan 24, 2006 | 10:14 AM
SOL Food's Avatar
^^i was talkin' about if he was still plannin' on gettin an engine swap....as in a lower mileage y8.
but you're absolutely right...no need to swap it out...the z6 can be boosted as well.
Old Jan 24, 2006 | 10:43 AM
Aztec Sol's Avatar
Default Re: (MARSH)
ok thanks. if i put a b16 in it would i have to worry about smog. and if i put a newer year z6 in it would the ecu work from my old z6?
Old Jan 24, 2006 | 10:47 AM
SOL Food's Avatar
it won't pass with a b16 swap. there are ways around it though (not illegaly) if you research or talk to your local smog refs/DMV.
legendarypk
Dec 12, 2009 06:59 AM
MUGEN_EG95
Nov 8, 2009 03:17 PM
dippy
Nov 1, 2008 12:52 AM
aero217
Jun 21, 2007 11:33 PM
B18Redline
10
Jan 4, 2006 04:43 PM
