DX tranny in VX ???
Old Jan 22, 2006 | 05:17 PM
schardbody's Avatar
Default DX tranny in VX ???
im thinking about changing my stock VX tranny out for a DX, maybe even an EX/SI, my questions are; what is the # on the ex/si tranny, and the part # of the DX tranny. i was also wondering if i would need to change anything keep the speedo accurate <--- main question. thanks in advance.
Old Jan 22, 2006 | 06:07 PM
schardbody's Avatar
bump please help
Old Jan 22, 2006 | 06:24 PM
SlowHX's Avatar
What's the year of the tranny/car?
And as far as I know you dont have to do anything to keep the speedometer accurate. That's what a VSS is for.
Old Jan 22, 2006 | 06:40 PM
schardbody's Avatar
its a 92vx, im not sure on the tranny yet, what do yall recommend???
Old Jan 22, 2006 | 06:43 PM
schardbody's Avatar
is the S20 tranny the SI/EX, and the B200 the DX, and the A200 the cx/vx?? if so thats all i need to know. if not im lost.
Old Jan 22, 2006 | 06:44 PM
GdmLaz's Avatar
K simple i would suggest at least getting an ex/si motor but if yuo don' t have money for that at least get an ex/si tranny shortest guears and no you just bolt on the tranny and you are good to go
Old Jan 22, 2006 | 07:20 PM
thisisntjared's Avatar
Default Re: DX tranny in VX ??? (schardbody)
dont worry about another motor. they arent that much more potent unless you stray from the d series or go with boost.
anyway for some real sustanence in this thread:
mista bone is my d series hero - http://home.cinci.rr.com/mistab0ne/tranny.html
as you can see, any transmission is better than the vx tranny. however you will lose some mpg. i say if cost is a concern just get the dx tranny. ex/si trannys usually cost more and you will lose an extra mpg with it.
the difference in ratios from the cx/vx tranny to the dx is MUCH greater that the difference from the dx to the ex/si.
bottom line - pick up a dx thats in good condition
Old Jan 23, 2006 | 06:33 PM
schardbody's Avatar
ok, i found the mista bones site after the post, but im still trying to figure out how to tell the differance between the DX tranny and the CX/VX, they both are small bearing cases and both are A000 right??? how to tell??
Old Jan 23, 2006 | 08:18 PM
Default Re: (schardbody)
you have to pull them appart. or make sure you know what car it came from
Old Jan 23, 2006 | 08:43 PM
96turboek's Avatar
it will bolt right up. and yes i would get the S20 out of the EX/Si. If you cant afford the full D16Z6 swap, do yourself a favor and switch out the VX intake manifold for the Z6/Y8 as it will flow better.
Old Jan 24, 2006 | 04:02 AM
schardbody's Avatar
i plan on swapping in the z6, but need to find some writeups of swapping into a VX, anybody know of any links.
Old Jan 24, 2006 | 04:07 AM
mario826's Avatar
Old Jan 24, 2006 | 05:08 AM
Sleepy_Red_hatch's Avatar
Default Re: DX tranny in VX ??? (mario826)
you don't need a wirteup....verry straightforward.....pull off all connections, remove motor, re install new motor reconnect everything, wire up the O2 sensor (VX uses a wideband) and your done.
Old Jan 24, 2006 | 05:16 AM
schardbody's Avatar
so the motor/tranny ecu is all plug and play with the exeption of the 5wire to 4 wire o2 conversion?? if so then thats not a problem.
Old Jan 24, 2006 | 06:49 AM
92vx-t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">so the motor/tranny ecu is all plug and play with the exeption of the 5wire to 4 wire o2 conversion?? if so then thats not a problem.</TD></TR></TABLE>
Yes.
I swapped out my vx trans for a dx trans, its alot better than the wider gears in a vx but honestly you best bet is to find a z6 or y8 trans.
Old Jan 24, 2006 | 07:37 AM
schardbody's Avatar
cool, you guys are awesome, i guess i know where to get my info from now on, thanks alot. Lee.
s1ngleslam
Oct 28, 2008 10:29 AM
flatblakd15vt
14
Mar 22, 2006 04:09 AM
Terrible One
Jul 10, 2005 10:50 PM
Purple_Civic
Jun 17, 2005 07:10 AM
AThiker
13
May 29, 2004 07:22 AM
