VTEC problem in LS/VTEC 90 CRX
Old Jan 22, 2006 | 04:40 PM
cjmech's Avatar
Default VTEC problem in LS/VTEC 90 CRX
I just built the engine and fired it up today. The wiring is correct (checked every wire 2-3 times) After it fires off it runs like crap unless you rev it up a little bit. After about 20 seconds it trips the CEL with a code 21 (VTEC Solenoid Valve) after the CEL it makes an intermitent metallic clack (fairly loud and inconsistent) unless I disconnect the psi sw and solenoid. The car runs great otherwise just need to get this figured out.
I pulled the solenoid and the screens are clean.....
Any ideas??
Chipped PR3 ECU, 90 Teg LS Bottom, PR3 Head.
Cj
Old Jan 22, 2006 | 06:54 PM
cjmech's Avatar
Default Re: VTEC problem in LS/VTEC 90 CRX (cjmech)
anyone have an idea?
Old Jan 23, 2006 | 04:50 PM
cjmech's Avatar
ttt
Old Jan 23, 2006 | 06:34 PM
1RMDave's Avatar
two things i'd check.
a) try a known good vtec solenoid
b) get an oil pressure gauge and see if you're making enough pressure for vtec to work.
Old Jan 24, 2006 | 08:59 PM
cjmech's Avatar
Default Re: (1RMDave)
Figured the problem out tonight. There was a small strand of wire connecting the VTEC solenoid and the #4 injector causing all my problems!!! It was injecting mass amounts of fuel into the #4 cyl so I thought it might have been an injector till I looked at the wiring schematic. Looked at the plug and thanks to a bright *** light I found the wire in the connector.
The wire was from the previous owner and there cheap attempt to make it work by stuffing a bare wire into the hole on the connector. When I pulled the wire out a few of the strands broke off in the connector and stayed there connecting the 2 pins.
Thanks for trying to help out, I appreciate it.
Cj
JDM94HATCH
12
Nov 15, 2006 02:06 AM
lsvteccivic
Oct 18, 2006 04:17 PM
vaporboy12
Nov 18, 2004 07:12 PM
