car squeaks
Old Jan 22, 2006 | 04:18 PM
1991AccordLX's Avatar
Default car squeaks
hey guys
i have a 1991 accord and it's been having these squeaky noises when i step on tha brakes ..i'm not really sure what it is. i have tried fixing tha brake pads in tha front and back but i can't seem to find out why it still squeaks ..anybody know what's tha problem?
Old Jan 22, 2006 | 04:41 PM
Ross 2.0's Avatar
In a Junkyard near you.
Is it related to the brakes or the nose of the car squatting when you apply them?
If it's just when you apply and release the brakes the rear shoes may be rubbing the backing plate. If that's the case just pop the drums off and put some good quality lube in there. I doubt you have rear disc brakes because I believe only the rare SE models had those.
Edited for spelling.
Modified by MooGoCow3 at 6:04 PM 1/22/2006
Old Jan 22, 2006 | 04:53 PM
YeuEmMaiMai's Avatar
Default Re: car squeaks (1991AccordLX)
make sure that the shims are installed between the pads and the caliper. Also, use some anti squeak on them if you haven't already...
Old Jan 22, 2006 | 05:35 PM
P_Adams's Avatar
Another thing you might try when you apply the "brake quiet" monkey snot to the back of the pads:
1) Take 80 grit sandpaper and rough up (deglaze) the pad's friction surface.
2) Retaining the brake rotors with a couple of lug nuts; start the car - put in gear and with the rotors spinning run a disc sander over the surface where the pads rub. It will impart a swirl pattern (like a cylinder hones crosshatch)
This will force the brakes to re-seat themselves, and should take care of the squeak at low brake pressures.
P
Old Jan 22, 2006 | 05:49 PM
Ross 2.0's Avatar
P keep the comments up. Your improving my evening of nailing tarps on my garage roof.
Old Jan 22, 2006 | 05:52 PM
P_Adams's Avatar
Default Re: (MooGoCow3)
What have you got up on that roof with you. A laptop, a wireless lan and a real long extension cord? LOL
P
Old Jan 22, 2006 | 05:54 PM
Ross 2.0's Avatar
how did you know? Are you watching me?
Old Jan 22, 2006 | 05:58 PM
noobie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991AccordLX &raquo;</TD></TR><TR><TD CLASS="quote">hey guys
do you have Honda pads on ??? if not, install Honda factory pads, resurface the rotors and the noise WILL go away..
If you got Honda pads on, resurface the rotors, smooth down the pads as it was stated earlier by MR P_.., use the gray grease that comes with honda pads on the pads, shims , put all together ....
hometheaterman
Nov 9, 2009 10:45 PM
otacon122
Oct 18, 2007 01:12 AM
GSRnold
Aug 22, 2004 04:29 PM
PearlWhiteAccord
Jul 11, 2002 06:09 PM
