..... easy question... are all D series throttle cable the same?
..... well I know that some of the brackets are different based on the IM your running. But as for the throttle cable it self, are they the same.
I was looking on hondaautomotiveparts.com but couldn't seem to find the right picture diagram for the throttle cables.
http://www.hondaautomotivepart...gry5=
thanks fellas.
thanks fellas.
welll i heard from another member that any 92-00 civic throttle cables are the same part # except for the 96-00 DX-d16y7 cables..
can anyone confirm?
can anyone confirm?
NO not all D-series throttle cables are the same.
Example, the D16Y7 (96 LX) takes a fairly long one while the D16Y8 (96 EX) takes a shorter one because of the throttle placement.
Someone also mentioned that the automatic and manual cars take a slightly different fitting (for the EK chassis, 96-00 Civics). (no idea why, nor can I personally verify this.)
What manifold are you running? Stock? Then yes i believe it will fit. You might need the ex throttle bracket though.
JasonHi
Jun 18, 2019 01:55 PM
boostedcvc
Feb 5, 2003 02:46 PM
