about EBC GREEN STUFF
Old Jan 22, 2006 | 03:17 PM
JUN.'s Avatar
Default about EBC GREEN STUFF
How good are this pads ?
Will I Increase my brake performance using this with stock rotors ?
Old Jan 22, 2006 | 03:26 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: about EBC GREEN STUFF (pakipr)
dont get them. get Hawk HPS pads. they are what you need.
Old Jan 22, 2006 | 03:29 PM
JUN.'s Avatar
Default Re: about EBC GREEN STUFF (sanimalp)
why not
Old Jan 22, 2006 | 03:30 PM
rsca_crx's Avatar
search
autox brake
in rr/ax forum
https://honda-tech.com/zerothread?id=950837
https://honda-tech.com/zerothread?id=159744
https://honda-tech.com/zerothread?id=148805
i copied over the links with the 3 most replies. i didnt proof any of them, as they usually all contain the same info. leave the reply button alone and go search it.
Old Jan 22, 2006 | 03:36 PM
fireant's Avatar
EBC has never been raved about in any racing circles I've seen.
Hawk HPS is a proven upgrade for the stock pads, many national level EF-hatch autocrossers use them as a great street/autox pad (I use them too!). Hawk HP+ is another step up... better grabbing and fade resistance, but noisy and dusty as heck.
The other thing to realize about pads, you can get a fancy track pad and it wont stop worth a damn in daily driving because the functioning temperatures need to be higher...so be realistic about your needs and choose an appropriate pad.
I also recommend bleeding out all your fluid with a pump while feeding in ATE super blue... when the fluid coming out is blue, then you're good to go.
Old Jan 22, 2006 | 04:22 PM
CRX Toad's Avatar
Default Re: about EBC GREEN STUFF (fireant)
EBC sucks get some real pads. Carbotech or Hawks a pad that has actual race proven competencies.
Fireant speaks truth.
Also Slotted/Drilled rotors will do nothing to increase braking performance so don't get those either.
Honda Civic (2001 - 2005)
12
Sep 12, 2007 07:18 PM
Champ R
Jul 25, 2003 10:52 PM
SuperRice
24
Jul 9, 2003 09:50 PM
Toda Party
Oct 8, 2001 04:42 AM
nonbox
Aug 23, 2001 02:06 PM
