help!
Old Jan 22, 2006 | 02:55 PM
86si's Avatar
Default help!
Well after installing my Exedy twin clutch and what i thought would fix any clutch issues i was having it seems no diff. when i rev the car up in gear with the clutch depressed it starts to move forward at like 6k. not just a little i mean it really lunges. i haven't road tested it yet cause its off the road for the winter.
I have changed everything on this god dam car, cable,pedal assembly and cage, you name it i've tried it. i never had this problem with my d-series trans in the same car. any suggestions. is this normal? it just doesn't seem right. i don't want to drive this thing and be locked out of gear at 9500 rpm like i was with my single disc clutch.
Last year left me very discouraged when everytime i went to the track i could not shift this thing. anybody have suggestions?
BTW its a YS1 trans. i have tried 2 diff trannies and no dice...wtf!
Old Jan 22, 2006 | 03:16 PM
THC07's Avatar
Default Re: help! (86si)
sounds to me like it needs to be adjusted out more. can you feel it completly disengage with the clutch down? if the vechile moves at all then there is some contact in the tranny on the clutch plates. what throwout bearing r u using?
Old Jan 22, 2006 | 03:23 PM
86si's Avatar
Default Re: help! (THC1107)
i have the cable adjusted tight and the pedal feels great. its an oem TO bearing
Old Jan 22, 2006 | 04:52 PM
THC07's Avatar
id assume you have played with the clutch adjustment? how about the pedel Adj?
somhow the pressure plate and clutch are rubbing and not fully releasing.
good luck, sounds like a pain.
Old Jan 22, 2006 | 05:17 PM
86si's Avatar
if i don't come up with something soon its goin up for sale
Old Jan 23, 2006 | 02:23 AM
86si's Avatar
anyone else?
Old Jan 23, 2006 | 12:11 PM
86si's Avatar
you mean to tell me no one has ever experienced this before??????
Old Feb 3, 2006 | 12:03 PM
nasteboyii's Avatar
Hey Dave
the best thing i can tell ya is it sounds like an adjustment issue
maybe the cable is stretched or ready to brake, and the load u put on it is not fully releasing/disengaging the clutch
stupid things ill throw out there,you said it did this both on d and b series, so first question is the cable the same cable, pedal same? is the pedal assembly in good shape my buddys crx was breaking so it flexed enough not to fully disengage
is there anything stupid u think u might have missed, if the cable housing is jacked up, it could cause not for full extension, Have someone watch it, (the transmission arm) see how far it moves, and then see if the can move any farther after pushing clutch in, with prybar or something
good luck dave
hope to see ya at the races soon
dan
Old Feb 3, 2006 | 12:04 PM
nasteboyii's Avatar
Thanks again for letting me borrow the lugnut off the element, At the Etown event, Lifesaver there (incase you forgot who this is, hope that reminds ya)
d
DntFk_jdm
Jul 17, 2016 05:19 PM
andlude
Transmission & Drivetrain
Apr 5, 2012 07:07 AM
bob_long737
Aug 19, 2008 07:41 PM
86si
Jan 23, 2006 09:01 AM
taytay333
Nov 21, 2001 12:58 PM
