engine cutting out bettween 1500-2000rpm why?
Old Jan 22, 2006 | 12:32 PM
littlegreenb18's Avatar
Default engine cutting out bettween 1500-2000rpm why?
as the topic says, its cutting out between 1500 and 2000, its a jdm b18c, p28 ecu. i thought it was the ecu for awhile, but i set all values in that range back to the stock p30 map, spark and fuel. and nothing changed. so what else could it be. please help
Old Jan 22, 2006 | 12:53 PM
TheThiefTheKnife'NTheGun's Avatar
Default Re: engine cutting out bettween 1500-2000rpm why? (littlegreenb18)
Check spark plugs,as well as the dizzy and wires
Old Jan 23, 2006 | 02:56 PM
Default Re: engine cutting out bettween 1500-2000rpm why? (TheThiefTheKnife'NTheGun)
ok, thats fine, but what would make that occure strictly in that rpm range? i don't see how, and therefore don't see how it would fix it. not hatin, just wondering if u know something i don't, but what the hell, i'll try it, i'm desperate
Old Jan 24, 2006 | 02:05 AM
bump. still need help
Old Jan 24, 2006 | 09:21 PM
well if you are dumping too much fuel at lower rpms and not having enough spark to burn it that would make it cut at lower rpms..
Old Jan 26, 2006 | 03:59 PM
i didn't touch the fuel map that low, but just to be safe i changed all the values back to the stock p30 map. didn't do jack
Old Jan 26, 2006 | 04:43 PM
743power's Avatar
stock p30 map is too lean for b18c
Old Jan 26, 2006 | 05:04 PM
Default Re: engine cutting out bettween 1500-2000rpm why? (743power)
i reaize that, but it really dosn't answer my question, i'm just trying to diagnose a problem here
Old Jan 26, 2006 | 05:06 PM
743power's Avatar
borrow a chip with a stock p73 or p72 program on it and report back
Old Jan 27, 2006 | 01:47 AM
at this point i'm pretty sure its not the ecu. i've tried ******* with it, tried going back to the base map i had, and like i said i even tried the p30 values at low rpm. i could just burn a p72 map on it, but i doubt it'd help.
Old Jan 27, 2006 | 12:38 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">at this point i'm pretty sure its not the ecu. i've tried ******* with it, tried going back to the base map i had, and like i said i even tried the p30 values at low rpm. i could just burn a p72 map on it, but i doubt it'd help. </TD></TR></TABLE>
I've seen ecu chips do weird things like this before.
nightscream
Engine Management and Tuning
Sep 18, 2011 12:27 PM
Sr420Det
Mar 21, 2010 09:50 PM
mtkhalid
13
Jan 29, 2009 07:03 PM
B18Tahtaras
Jul 7, 2005 12:06 AM
boosted_zc
May 25, 2003 08:58 AM
