OBD Questions
Old Jan 22, 2006 | 10:38 AM
A-TL's Avatar
Default OBD Questions
I'm in need of a help from all you techs and tuners out there.
I'm in the process of dropping an OBD2 motor(98 B18C1) into a OBD1 shell
(95 GSR).
What components will I need to crossover this into a OBD1 besides the ECU?
Can I still utilize the OBD2 engine harness or should I swap into a OBD1?
Any advise would help.
Regards,
A-TL
Old Jan 22, 2006 | 11:10 AM
nickG's Avatar
Default Re: OBD Questions (A-TL)
youll need an odb1 dizzy and ecu for sure..
probably some other things..
but you can use the obd1 harness already in the car
Old Jan 22, 2006 | 01:14 PM
teg racer 877's Avatar
Default Re: OBD Questions (nickG)
no you dont need an obd1 dizzy, I put a 01 ls into my 95 gsr shell, im using a 94 ls ecu, I did not think it would work but ive been driving it for 2 years now, all I did was swap one plug under the dash that I noticed was different and it worked.
Nisif
Oct 20, 2012 06:11 PM
aaronISthrowed
Aug 16, 2009 12:23 PM
96electronH
Sep 18, 2008 03:46 PM
so simple
Mar 3, 2007 08:12 PM
VTECth1s
Jun 7, 2006 05:51 PM
