NEED SUGGESTION ON MY very first PROJECT ~~MILD UPGRADE
Old Jan 22, 2006 | 04:12 AM
liebig40's Avatar
Default NEED SUGGESTION ON MY very first PROJECT ~~MILD UPGRADE
hi i m going to do a B18C1 swap on my 96 civic coupe and i need some suggestion and i want to know how much WHP i m looking at ~ and i want to know whether i should go for koyo radiator or oil cooler ?because i need them for longer life for the engine since i have to drive it day and night and little need for speed here is the list for my first stage small project :
Aem short RAm cold air intake
Aem fuel presure regulator
Aem fuel rail
ITR intake manifold
70mm throttte body
4-2-1 header (whole pipe wrapped )
mugen muffler exhaust
1 lb aluminu crank pulley ( no AC. no power steering , just keep the alternator)
ACT clutch kits with 6 pucks disc
8lb fidanza flywheel
ground wire harness
koyo radiator / oil cooler ( haven't decided yet )
performance oil pump ( haven't decided yet )
momo steer
racing seat
replacing 17 inch rims to 16 rims ( weight reduction )
ripping off the back seats , passenger and driver seats replacing them with racing seat
carbon fiber hood
skunk 2 coilcover
sway bar ( upper , lower )
drill brake rotor , alumium brake hose . gsr master cyclinder
anyway i know i m not really getting lot of horse even though i've put all these stuffs into my engine and i want to know shall i use performance oil cooler or radiator ? and i know ebay stuff is not trusting but i need these 2 items for killing heats from engine only and there is no machinery inside these 2 items so should i go for ebay thanks for reading
second stage :
mugen . hondata ecu
racing cam
racing piston
LSD
Old Jan 22, 2006 | 05:05 AM
old man neri's Avatar
Default Re: NEED SUGGESTION ON MY very first PROJECT ~~MILD UPGRADE (liebig40)
I wouldn't bother with cross-drilled brake rotors, really no advantage and it has been debated to death.
You may wish to invest in this:
Cheers
Old Jan 22, 2006 | 05:54 AM
SovXietday's Avatar
Default Re: NEED SUGGESTION ON MY very first PROJECT ~~MILD UPGRADE (old man neri)
It's really hard to say what kind of power you're gonna get, GSR is a nice engine but tuning will prove how much you can squeeze out of the thing.
vtecislife
Jul 12, 2014 06:34 PM
Conflicted
Mar 29, 2012 07:30 PM
boostlee
Oct 8, 2003 11:16 PM
