CRX b16a2 swap pre-obd to obd2
Old Jan 21, 2006 | 11:54 PM
lifesk8err's Avatar
Default CRX b16a2 swap pre-obd to obd2
I have a b16a2 it is uh.. hold on.. backup I have a stock 1989 crx. i am converting to obd 2 with my ECU (p72) and i have a b16a2 any suggestions to what i have to do for the wiring conversion... just teh harness and connectors... just the harness..etc.
thanks,
B
Old Jan 22, 2006 | 12:01 AM
.Manny.'s Avatar
Touching My Member
why do you want to go obd 2?, just convert to obd1, which is much better and get a chipped p28
Old Jan 22, 2006 | 12:05 AM
Pee Wee's Avatar
Default Re: (90_EF_Si)
what he said ^^^^^^^^^^
Old Jan 22, 2006 | 12:11 AM
elrandeeto's Avatar
Default Re: (EF8opey)
agreed
Old Jan 22, 2006 | 01:09 AM
crxnj's Avatar
Default Re: (elrandeeto)
Jus eliminate the crank sensor on the motor and consider it obd1..You can use the obd2 distributor when converting your harness to obd1..There just arent many tuning options with obd2 hondas..So like said your best bet is convert to obd1 and run a chipped p28..
Old Jan 22, 2006 | 04:42 AM
eda6's Avatar
Default Re: (Mr.speaker)
obd1 chipped p28
p28 doesn't look for the knock sensor
Old Jan 22, 2006 | 08:52 PM
lifesk8err's Avatar
Default Re: CRX b16a2 swap pre-obd to obd2 (lifesk8err)
TY very much for your input. I was told by my cousin to buy a GSR ECU. and when researching the p28 I thought that they were out of a SOHC engine. that is why I picked the p72 because it stated that it was out of a DOHC. but none the less thanks for the reply's everyone and I will take your advice and purchase a p28. now when I wire up the obd1 does anyone know where I can go to view a step by step on what to do to my harness so it all matches up?
thanks again
Old Jan 22, 2006 | 09:01 PM
Pee Wee's Avatar
just get the harness from jkobd.com makes everything so much easier
Old Jan 22, 2006 | 09:02 PM
Pee Wee's Avatar
Default Re: CRX b16a2 swap pre-obd to obd2 (EF8opey)
they also have obd 0 to obd 2 harnesses if you actually want to go obd 2
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lifesk8err &raquo;</TD></TR><TR><TD CLASS="quote">TY very much for your input. I was told by my cousin to buy a GSR ECU. and when researching the p28 I thought that they were out of a SOHC engine. that is why I picked the p72 because it stated that it was out of a DOHC. but none the less thanks for the reply's everyone and I will take your advice and purchase a p28. now when I wire up the obd1 does anyone know where I can go to view a step by step on what to do to my harness so it all matches up?
thanks again</TD></TR></TABLE>
Thats why everyone is saying "chipped" p28..p28 chipped with timing/fuel maps for whatever motor you're using..
As far as converting to obd1 you could get one of those jumper harnesses and be done with it..But if you want to try it yourself check this out..http://www.knology.net/~jediklc/obd0toobd1swap.htm
Old Jan 22, 2006 | 10:29 PM
Rywire's Avatar
Default Re: CRX b16a2 swap pre-obd to obd2 (Mr.speaker)
dont use a gsr ecu on a b16a.... the gsr has iab's. Not so good for a b16a
chaos304k
Apr 10, 2019 08:30 PM
Etorres325
Feb 5, 2010 09:21 PM
BlueRex1020
Mar 4, 2007 12:41 PM
HYREV2NR
Jul 27, 2003 04:28 AM
StinkyTofu
Feb 4, 2003 08:54 PM
