Nitrous on a d16 ????
Old Jan 21, 2006 | 03:36 PM
175Shot4Door's Avatar
Default Nitrous on a d16 ????
i have a short ram intake,header,and a full cat with 2.5 inch piping and a aem truetime cam gear and nitrous with 175 shot jet not hoked up yet....how long do u think it will hold for if the motor has a 140,000 miles if i spray a 50 or 75 shot ?
Old Jan 21, 2006 | 04:09 PM
97spooncivic's Avatar
Default Re: Nitrous on a d16 ???? (175Shot4Door)
i have been spraying 50 for a while and nothing has happend. you car might melt and you need colder spark plugs. mine is a wet kit, is yours dry or wet? my brother managed to use 150 shot on a dry kit about 1.5 runs.
Old Jan 21, 2006 | 04:22 PM
wet but i no longer have it lol as of an hour ago..im going to buy a dry kit i belive becuase i heard if your going to spray a 75 or lower go dry becuase wet is alot harder of your motor
Old Jan 21, 2006 | 04:41 PM
what, i have never herd of that. dry is more dangerous for your motor from what i have herd
Old Jan 21, 2006 | 05:54 PM
murmur9's Avatar
Default Re: Nitrous on a d16 ???? (97spooncivic)
What he said. Dry is more dangerous. if still using stock injectors and fuel pump. it would be better to upgrade those if going dry. Do you know the diff. between wet and dry?
on a d16...dont go about 75 shots.
wet - adds the extra fuel needed during nos use. taps into fuel line to make it safer,
dry- depends on stock parts or aftermarket parts to bump up the extra fuel needed....if you use stock stuff on dry...usually runs lean
wet usually goes more rich then lean. which isnt as bad. isnt good. u should do some dyno pulls to even the a/f out
BojeEM2
Honda Civic (2001 - 2005)
14
Sep 12, 2007 02:13 PM
0618turbocivic
Jul 25, 2006 08:38 AM
gsrtxjarrod
Jan 8, 2005 09:33 PM
MooreBoost
Feb 18, 2004 10:18 AM
blacklude
Oct 14, 2002 01:57 PM
