Help with 1.6 non vtec to 1.6 vtec
Old Jan 21, 2006 | 11:01 AM
s_vares's Avatar
Default Help with 1.6 non vtec to 1.6 vtec
Well I did the swap (d16y7) 99civic coupe in my 93 civic HB with a d16y8 head
im having a few problems.
some info....
no cel
brand new exhaust with header front to back
-no cel
-d16y8 block
-d16z6 head
-all d16z6 computer, harness, injectors, sensor, intake, tb, timing belt, and camsprocket.
-valves adjusted
-timed to 16deg. Before TDC
-fuel pressure checked and perfect
-injectors good
-compression outstanding
BUT!!!
Car misses slightly at idle, vibrates and rough thru entire rpm range(may be another problem), runs fairly rich. I think its timing!!! I was using a d16y7 timing belt just changed it to d16z6 belt, they seem the same, still having those problems. HELP ME!!!
Im thinking timing gear, but im not a big time honda engine builder i know SOME of you guys are so if you can help me out id love ya....
Steve
PS
-cool tibit of info.... stock d16y7 suppose to time to 12 deg before TDC but as i read with the Z6 head to time to 16 deg. which most hondas are. Car runs poor at 12 before tdc.
Thanks
Old Jan 21, 2006 | 11:53 AM
s_vares's Avatar
Default Re: Help with 1.6 non vtec to 1.6 vtec (s_vares)
sorry i said somthing wrong
My swap was
D16Y7 Block
D16Z6 Head and ECU/sensors
Sorry Guys
Steve
Old Jan 21, 2006 | 12:02 PM
robert_v's Avatar
my runs at 16* tdc. its the same set-up.
Old Jan 21, 2006 | 12:08 PM
s_vares's Avatar
Which cam gear should I use????
Is the Z6 one wrong for this application?
Steve
Old Jan 21, 2006 | 12:16 PM
robert_v's Avatar
Default Re: (s_vares)
i'm using the y8 cam gear.
Old Jan 21, 2006 | 12:38 PM
s_vares's Avatar
Y8??? im using the D16z6 One
but I have a Y7 block.... Great.... im so confused
Old Jan 21, 2006 | 01:06 PM
BauleyCivic's Avatar
Risky Business
Is the cam timing correct?
Old Jan 21, 2006 | 01:19 PM
s_vares's Avatar
NO! lol just checked its off 1/2 to maybe 3/4 of a tooth off. Would this cause my problems?
How can i fix?
Camgear??!! I KNEW IT
JDMDC4life
Jul 24, 2014 08:27 AM
IHEARTMYHONDA91
Nov 27, 2008 06:31 PM
ssl2k
Feb 24, 2005 11:16 AM
